does know how to mount this part
Old Oct 3, 2011 | 03:31 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
Last edited by 1983cameroman; Oct 3, 2011 at 03:32 PM. Reason: talking about bracket
Old Oct 3, 2011 | 03:58 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: does know how to mount this part
It's been awhile since I've owned a 454, but isn't that one of the two ac brackets....
Old Oct 3, 2011 | 04:03 PM
Engine: 468bb
Transmission: 700r
suppose to be alt mounting bracket to low mount alt bought on ebay person who sold will not contact me
Old Oct 3, 2011 | 04:12 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Ya there are two bolt holes on sbc and bbc with threards on left and right side on front of the blocks
Old Oct 3, 2011 | 05:02 PM
Originally Posted by 1983cameroman
suppose to be alt mounting bracket to low mount alt bought on ebay person who sold will not contact me....
There should be another piece that is used in conjunction with relocating the alternator to a lower position....
Old Oct 3, 2011 | 05:10 PM
Engine: 468bb
Transmission: 700r
this is pic for add only place two bolt holes is water pump mounting holes then will bolt to head
Old Oct 3, 2011 | 05:15 PM
Do you have a larger picture than that....?
Old Oct 3, 2011 | 05:26 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You see the two threaded holes in the water pump, just above the inlet. The lower alt bracket attaches to those. It looks like the bracket you have serves as both a lower and upper bracket.
Old Oct 3, 2011 | 05:29 PM
Engine: 468bb
Transmission: 700r
to bolt up there only one hole lines up and willnot bolt to headand that is the biggest pic they gave
Old Oct 3, 2011 | 05:32 PM
Engine: 468bb
Transmission: 700r
willtry again tom thanks terry
Old Oct 3, 2011 | 05:44 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Where does the other hole line up?
Maybe get an alternator spacer tube the other bolt goes thru & cut it to fit the length, IDK if that will help, just a thought
Old Oct 3, 2011 | 05:48 PM
Engine: 468bb
Transmission: 700r
toplines up but hole in head doesent only way all three hole line up is using water pump mounting holes bought some tubbing to cut for spacers
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
