383 swap questions
Old Nov 22, 2011 | 06:27 PM
john.wesley's Avatar
383 swap questions
the car was 400 dollars, has stock everything, minus the motor and tranny. i have a 383 and turbo 350 tranny. after i throw the motor and tranny in (coming out of my 85 camaro and goin into a 91) how do i even begin to rewire it, and what all do i need to do?
getting the motor in is the easy part just dont know what to do from there. car has stock wiring harness etc. is it just an easy hook up or what?
Old Nov 22, 2011 | 07:13 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: 383 swap questions
What setup? Carb, TPI, TBI? How do you expect any of us to answer that question with barely any information. Either way you cut it it shouldn't be rocket science, simple SBC swap.
Old Nov 22, 2011 | 07:17 PM
my bad. at work and had to make it short. its a 383 roller rocker double humped heads, bored 30, 400 crank, gear to gear timing, its carb.
thats what i was hoping. never actually done this before.
Old Nov 22, 2011 | 08:04 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Yea... but what car is it going into? Tbi, carb....
Old Nov 22, 2011 | 08:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
its carb.
From your original engine bay wiring ( if still in place )
you need a wire to the coil and one to the starter plus the wiring for gauge senders in engine.
Some means of operating fuel pump and fans
https://www.thirdgen.org/forums/engi...n-1st-car.html
Old Nov 22, 2011 | 10:50 PM
1gary's Avatar
With it being a TBI originally,you could use the in tank fuel pump just be using a return line fuel regulator.You have to do that because the TBI in tank fuel pump has too much pressure.
Old Nov 22, 2011 | 11:42 PM
I'm not too sure what it originally was. I will check tom. Still working out the Details on the buy.I'm pretty sure since its been sitting with no motor or gas the tank ifor years, it's prob rusted out. Which means I will prob be switching the tanks as well. I would just swap interiors, but since mine is gutted, roll cage, homemade dash etc and my exterior literally has a dent on every panel it'll be cheaper to buy and swap.
Old Nov 23, 2011 | 01:06 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
check out the carb swap threads, its basically the same process after you get the engine in the bay. (except youll already have the intake, carb, and dizzy)
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
