454 engine swap
Old Jan 5, 2012 | 09:50 PM
hooksonme's Avatar
454 engine swap
I am trying tp put my 454 into my 91 rs, having oil pan clearance issues.
any suggestions.....
Old Jan 5, 2012 | 10:08 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: 454 engine swap
What is it hitting Mine went right in
Old Jan 5, 2012 | 10:55 PM
hooksonme's Avatar
Re: 454 engine swap
pan to cross member
Old Jan 6, 2012 | 11:38 AM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: 454 engine swap
what kind of motor mounts With a stock pan and motor mounts should be no problem Mine went in using stock SBC mounts
Old Jan 9, 2012 | 07:16 PM
fastllort's Avatar
Re: 454 engine swap
I never even thought of this!
Good idea
Old Jan 9, 2012 | 07:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 engine swap
I never had a problems with mine when I had a stock k-member. Started with stock mounts then went to solid mounts. I think I was always using a Moroso "Chevelle" pan and never had a clearance problem with it.
When I put in a tubular k-member, I eliminated the side mounts and used a motorplate to support the engine. With the motorplate, I lowered the engine and moved it back as much as I could.
Old Jan 9, 2012 | 08:06 PM
Re: 454 engine swap
Depends on the pan you have.
If it's a truck or full-size car pan, good chance it won't fit. The front of the sump will hit the exhaust and/or the frame.
If it's a Chevelle, MC, or Camaro pan, drop right in.
Get the right pan and your problems will magically vanish.
Old Jan 24, 2012 | 06:05 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
Re: 454 engine swap
sounds like you have truck pan
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
