5.7 T5 Swap Bellhousing Problem
Old Jan 24, 2012 | 09:12 PM
91SR71's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Transmission: borg warner T-5
Axle/Gears: 3.08 open
I just swapped out my 5.0 for a 5.7 and the bell housing has a gap between it and the block. I'm running the stock T5. The top bell housing bolts are tight but the bottom bolts on either side won't snug up. Is there anything I can do short of pulling the motor and trans again?
Old Jan 24, 2012 | 09:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I moved this to its own thread because, although your car is a Pontiac, the engines you're talking about are not.
Old Jan 24, 2012 | 10:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 5.7 T5 Swap Bellhousing Problem
Did you center the clutch disc?
Is bellhousing sitting on the alignment dowels square
And loosen the top bolts off before you break or bend something.
Something is stopping trans pulling up square.
You never only tighten one set of bolts; should do all bolts progressively
Old Jan 25, 2012 | 07:49 AM
85_ZED28's Avatar
Car: '85 Z28
Old Jan 25, 2012 | 12:26 PM
ex-x-fire's Avatar
Are you puting on the bellhousing alone or is the tranny still bolted to it?
usafirebird
Sep 29, 2015 11:58 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
