NEED HELP!!!
Old Jan 8, 2012 | 10:33 PM
Rysnyder24's Avatar
NEED HELP!!!
Hi there im really having problems with my project car. i bought a 1989 iroc-z that someone was using as a parts car(first mistake there) they cut a bunch of wires but i replaced the missing wires. i recently bought a 1990 350tpi from a camaro iroc-z i put the motor and engine wiring harness in the car and plugged in the computer. now the problem i am having is the injectors arent firing and its not vats we have ruled that out already. also the wires arent matching up from under the dash of the car to the wires that run to the outside of the car. my question is has any done a similar swap and if so what wires had to be spliced and where they have to go. thanks!!
Old Jan 9, 2012 | 12:10 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: NEED HELP!!!
did you get the wiring harness and computer from thr 90 350? if not there are difference detween pin locations. check out http://www.austinthirdgen.org/index.php?pid=19 and compare the 2, youll probably have to repin the harness.
Old Jan 9, 2012 | 02:17 PM
Rysnyder24's Avatar
Re: NEED HELP!!!
yea i got the harness from the 1990 camaro so all i have to do is repin the harness? the problem is that under the dash on the passenger side there are the injector wires running from the fuse box to a plug that is close to the ecm. i need to figure out where i can splice those wires into the harness so the power can get the injectors.
this is a picture of the plug that the wires from the fuse box run to.
Old Jan 9, 2012 | 03:18 PM
travis401's Avatar
Car: 91 Camaro RS
Re: NEED HELP!!!
if you use the 90s computer it will all just plug in without issue. to use the 90s harness with the 89s computer youll have to change pins around on the harness plugs. all those plugs are for is power for the injectors. the 2 pink wires are the switched 12v for the left and right banks and the black is the ground. you can run them to really any spot that has a fused switch 12v source.
Old Jan 9, 2012 | 04:54 PM
Rysnyder24's Avatar
Re: NEED HELP!!!
what I'm not understanding is underneath the dash i have wiring for an 1989 and what I'm told is i can't use the wiring under the dash with the 1990 engine harness. can you explain to me how i can get pulse to my injectors. thats the only issue I'm having with the car thanks a million
Old Jan 9, 2012 | 05:00 PM
travis401's Avatar
Car: 91 Camaro RS
Re: NEED HELP!!!
the engine harness should be seperate from the dash harness. if youre using the 89 computer VATS wont be an issue, if you use the 90s computer youll have to either get a VATS bypass box or have it tuned out. the injector wires there just need a fused switched 12v source, since i dont think on the 89 they had a spot on the fuse panel for the injectors. someone with more experince on swapping harnesses between years will probably chime in.
Old Jan 9, 2012 | 05:35 PM
Rysnyder24's Avatar
Re: NEED HELP!!!
Thank you very much I'm hoping someOne with more experience will chime in soon this is the only thIng stopping my far from running haha
Old Jan 9, 2012 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: NEED HELP!!!
What more do you want?
Which computer are you running?
If you have the 89 computer on the 90 wiring then you have to mods to do because they are completely different control systems; even thought the intakes are the same
Old Jan 9, 2012 | 09:07 PM
Rysnyder24's Avatar
Re: NEED HELP!!!
when i got the car it had nothing in it except cut wires all over the place except under the dash. so i went and bought a 1990 350tpi from a camaro and got the wiring harness and computer. put the motor in and wired it and plugged in the computer now my problem is im not getting a pulse at the injectors when i crank the engine over and i have that plug which i posted the picture above so im stuck i have a guy telling me that i need a 1989 engine wiring harness and computer but im trying to see if i can get this to work out somehow
thank you very much for your help.
