Fuel issues
Old Jan 12, 2012 | 10:52 PM
Kurtis2short's Avatar
Fuel issues
I have a 477 tall block with no fuel boss some I'm running an electric Holley black series fuel pump the most I seem to be able to get out of it is 12 psi I'm using the stock fuel lines could that be what's causing it if so what's an ideal size my motor will turn 10000 with no issues and has a 1050 demon series carb any ideas I have a Manuel sending unit in the tank
Old Jan 13, 2012 | 02:54 AM
Mangup's Avatar
Re: Fuel issues
Holley Black should produce 14psi. If not, then possibly stock lines are restricting flow - Not just pressure, but also volume. If the pump is pulling fuel rather than pushing (i.e. rear fuel tank with pump mounted in the front of vehicle) this would also affect pump performance. If you're running a Demon carb then you should only need less than 9psi through a regulator. Set your regulator per carb instructions, then check your fuel pressure at WOT to make sure it doesn't drop. You might be OK if the motor is NA. If you want to be safe, mount the pump at the tank and run 1/2" hard line forward. Keep in mind requirements for return lines depending on your setup.
Old Jan 13, 2012 | 03:06 AM
Re: Fuel issues
I have the fuel pump at the front by my motor and it's drawing from the tank and it's a thirsty big block we dynod it using 16 psi for maxing performance do u think if I use a inline fuel pump about halfway it'd help as well
Old Jan 13, 2012 | 12:55 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Fuel issues
electric pumps work better as pushers, not pullers. put the pump as close to the tank as possible and that should help get more flow. did you sump the tank or are you running through the stock sender and lines? if using stock, did you remove the in tank pump if it had one?
Old Jan 13, 2012 | 02:44 PM
Re: Fuel issues
It's got the stock sending unit no pump in the tank and I'm using the stock lines
Old Jan 13, 2012 | 02:59 PM
travis401's Avatar
Car: 91 Camaro RS
Re: Fuel issues
then you shouldnt have a problem. id still highly suggest moving the pump close to the tank
Old Jan 13, 2012 | 03:15 PM
Re: Fuel issues
I'll try moving the pump halfway and see what happens
Old Jan 13, 2012 | 03:17 PM
Mangup's Avatar
Re: Fuel issues
If it had 16psi on the dyno, are you using a regulator between the pump and the carb? The carb is optimized to run on less pressure, and so you would need to reduce the fuel pressure to about 6psi and then jet accordingly.
Old Jan 13, 2012 | 03:29 PM
travis401's Avatar
Car: 91 Camaro RS
Re: Fuel issues
agreed, if its carbed, 16psi at the carb is WAY too much
Old Jan 13, 2012 | 03:31 PM
Re: Fuel issues
I using a hokey regulator as well that's what I'm running. My return from and the carb has been rejected etc the shop built my carb as well
Re: Fuel issues
A Holley regulator
Old Jan 13, 2012 | 03:40 PM
travis401's Avatar
Car: 91 Camaro RS
Re: Fuel issues
what psi are you getting to the carb?
Old Jan 13, 2012 | 07:07 PM
Re: Fuel issues
I'm getting 12 to the carb and it's just seems to tickle in a sense not spray if I floor it it falls on its face and wants to DIEbut 3/4 throttle and I can spin the tires and whip your head back it's in time the shop said its fuel issues any ideas
Old Jan 13, 2012 | 11:06 PM
Mangup's Avatar
Re: Fuel issues
It wants to die when you floor it because the mechanical secondaries are opening and theres way too much fuel (too rich), probably because of the fuel pressure. The regulator needs to be adjusted so that correct pressure is being delivered to the carb. (See page 7 of the manual in the link.) Then you can jet and make any other carb adjustments needed. Among other things, high fuel pressure will put float adjustment out of whack, and the carb will never work properly.
http://www.barrygrant.com/frombarryg...0manual-08.pdf
Old Jan 14, 2012 | 09:32 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Fuel issues
5-6psi is what you need for a carb, 12 is still way to much.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
