L98 vette
Old Jan 16, 2012 | 06:42 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
L98 vette
I am able to get a 350 TPI out of a TA for 150, needs new crank bearings, for $150, no wiring or anything. I am also able to get an L98 out of a vette with all wiring and accesories, it has a 6 speed manual trans for about 200. has aluminum heads i believe. would the computer work with a 700r4. and also what do i need to change on the vette motor to put it in my car. stock TA with a 305 TPI. thanks
Old Jan 16, 2012 | 08:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L98 vette
Originally Posted by dctrouant1995
I am also able to get an L98 out of a vette with all wiring and accesories,6 speed manual trans
You would use your existing TPI computer and wiring with the Vette engine and a 350 auto chip
or tune in your computer to replace the 305 tune
Everything that bolts to the front of the engine from your car
Old Jan 17, 2012 | 07:54 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: L98 vette
Ok, thanks! I noticed the vette doesn't have a smog pump. So what do I do about that? What about the oil pan? I have read that it doesn't fit, true or not? thanks
Old Jan 18, 2012 | 12:39 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: L98 vette
It did have from factory but you are using all the front parts off your old engine so no problem
Prob won't .
Vette pan is shallower and the sump on the pan is longer because the engine sits behind the front suspension , not over it like most cars.
Must use oil pickup to suit the pan being used; don't interchange
Recall F-Body pan more like the ZZ4 one shown on left.Vette pan on right
Old Jan 18, 2012 | 06:25 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: L98 vette
Ok thanks for all the info. So the vette pan will fit? And also do I have to retune my computer after gettin a 350 chip?
Old Jan 18, 2012 | 01:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, the Vette pan will NOT fit. You need to change it. The good news is your 305 pan will fit the Vette engine. Change the oil pump while you're at it.
I had a ZZ4 pan in my 3rd gen, so I can attest to it fitting as well.
Old Jan 18, 2012 | 06:31 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: L98 vette
alright thanks!
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
Tarizza
Sep 24, 2015 12:57 PM
