Worth the swap?
Old Jan 24, 2012 | 04:46 PM
Dusk2600's Avatar
Car: 85 z28,01 sonoma,05 envoy
Engine: 305 tpi
Transmission: 700 r4
Axle/Gears: stock
Worth the swap?
my 85 z28 has 71k orig miles it is a 305 tpi. I have found a jasper 5K mile 350 for around $500. It has paperwork. he claims it has bigger fuel injectors. Is it worth swapping if my motor has nothing wrong with it. I don't plan on doing any kind of upgrades just drop it in. I Know this 305 to 350 swap has been argued time and time again, but because theres nothing wrong with my set up i am unsure and if im not modifying this New 350 is it really worth swapping? Any help is appreaciated.
Old Jan 24, 2012 | 04:47 PM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
Re: Worth the swap?
my car is rust free as well and straight, from a performance standpoint stock to stock is it worth it
Old Jan 24, 2012 | 06:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Without knowing details on the Jasper engine, such as heads and cam, I wouldn't make a call on it. You could end up with a boat anchor that doesn't have any more power than the 305.
Old Jan 24, 2012 | 06:25 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Worth the swap?
by the time you swap it in it will probably cost you 1000 dollars replacing things that break and making it work with your computer.
Old Jan 24, 2012 | 06:29 PM
five7kid's Avatar
'85 TPI is MAF. The computer won't have any problem with it (although changing out the knock sensor and module would be a good idea).
Old Jan 24, 2012 | 10:33 PM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
Re: Worth the swap?
This is what i am afraid of, to my knowledge it was built to stock specs minus the fuel injectors, if my motor was bad this would be a no brainer but the "if it ain't broke don't fix it" comes into play.
Old Jan 25, 2012 | 02:21 PM
five7kid's Avatar
Originally Posted by Dusk2600
... to my knowledge it was built to stock specs ...
But, stock "what"? Could be a "stock" truck, "stock" TBI, etc. More information needed.
Old Jan 26, 2012 | 12:03 AM
Dusk2600's Avatar
Engine: 305 tpi
Axle/Gears: stock
Re: Worth the swap?
the moitor is from a 92 camaro
Street Lethal
Apr 30, 2019 12:14 PM
draco
Oct 4, 2015 09:25 PM
bellez77
Sep 5, 2015 08:39 PM
lt1z350
Aug 28, 2015 05:57 AM
hokis
Aug 9, 2015 03:57 PM
