4th gen Vette Engine and Trans in a 86-90 T/A
Old Jan 27, 2012 | 10:44 AM
78n91camaro's Avatar
Hey guys, I was wondering if a 1984 corvette engine and trans will fit into a 86-90 T/A it was an original V-8 car, I don't remember the exact year but it has the WS6 option.
Old Jan 27, 2012 | 11:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 4th gen Vette Engine and Trans in a 86-90 T/A
welcome to TGO
a small block chevy is the same size, regardless of the application. you will have to reuse your accessory drive system and exhaust
Old Jan 27, 2012 | 11:13 AM
Alright thank you, i just wanted to double check and make sure.
Old Jan 27, 2012 | 07:14 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the trans will not fit without modification.
Old Jan 27, 2012 | 07:16 PM
Rear tail shaft housing for the torque arm i would guess?
Old Jan 27, 2012 | 07:28 PM
zenish's Avatar
Engine: 305 tbi
i actually don't know.you might be able to swap tailshafts if the vette is 700r4 also.i just wanted you to know there could be a problem because of the torque arm mount.
Old Jan 27, 2012 | 07:30 PM
ya, i figured that would be the only problem i would have, i know the 3rd gen f bodies pretty well, just wasn't sure how the vette would match up to it.
Old Jan 27, 2012 | 08:15 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by zenish
.you might be able to swap tailshafts if the vette is 700r4 .
Tailshaft housing swap is no problem
May have a problem with Vette trans because many don't have the holes underneath
( or even the casting that can be drilled / tapped ) for the trans mount on the case
Old Jan 28, 2012 | 11:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just keep in mind that the crossfire 350 in the 84 vette was a boat anchor. I'd never go through the effort of swapping in that motor.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
timonator
Aug 11, 2015 09:56 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
