Engine swap
Engine swap
I have a 85 trans am with the 305 4bbl, Im looking to do engine swap with a stroker engine my first choice is a 454 storker and my second choice is 400 storker I no a 400 would fit but would a 454 fit. I would Appreciate information before I decide on a block.
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
Re: Engine swap
the 454 will fit u just have to have the right oil pan
Transmission: 4L80E/4L80E
The "typical" 454 is a big block. However, you can make a 454 small block.
Either will "fit". For the big block info, check the sticky in the top section of this forum about BBC swaps.
For information about a 454 small block, check with your banker.
theshackle
Mar 5, 2017 06:37 PM
