4.3 Vortec without computer
Old Feb 8, 2012 | 12:42 PM
kauaikarl's Avatar
I'm helping a friend install a 4.3 Vortec in a 58 Jeep FC truck. The one thing not wanted is the computer. What intake manifolds are available and what carburetor would work? Just want something that runs well, not going for 10-sec quarter miles. What other issues will I have if not using the computer?
Old Feb 8, 2012 | 12:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 4.3 Vortec without computer
Edelbrock 2114, you don't state what transmission he is using. That maybe the only concern with not having a ecm.
Old Feb 8, 2012 | 12:55 PM
kauaikarl's Avatar
The plan was to use the stock transmission. The engine/trans came from a Chevy truck.
Old Feb 8, 2012 | 01:03 PM
Engine: Lb9
Transmission: M20
4L60E ? If so you can install a tcc lockup kit from tci 376600
Old Feb 8, 2012 | 01:45 PM
kauaikarl's Avatar
checking the trans later today. I think that's the one. I heard about something called Compushift for about $1100. Thanks I'll look into TCI, don't know who they are yet.
Old Feb 8, 2012 | 05:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by tunedperformanc
4L60E ?
Needs a controller for the "E" version as everything in trans is controlled by the PCM
Lockup kit only works with earlier T700 /4L60 which would be the cheaper option for the OP in this case.
Sell / swap the "E" trans from the truck for a 4L60 that only needs convertor lockup ; not a $1K controller
$10 of parts from Radio shack will get you convertor lockup function
Old Feb 8, 2012 | 05:17 PM
Engine: Lb9
Transmission: M20
Opp's typed that wrong, Like vette oz said if you don't have a 700r4 get one.
Old Feb 9, 2012 | 12:28 AM
kauaikarl's Avatar
yes, the transmission is that number...it's the "E" version...
Old Feb 9, 2012 | 12:51 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It will not operate without the stock PCM or an expensive aftermarket controller
Seriously consider swapping it for the non-Electronic version
For a carb swap ,you can get the earlier T700/4L60 trans modified with a internal switch so you only have
to run 1 wire to it and the convertor will automatically lock up every time it goes into 4th gear
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
monte87cortez
Sep 26, 2015 08:10 PM
Damon
Sep 26, 2015 04:29 PM
