Big Block Owners
Old Feb 13, 2012 | 01:04 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Big Block Owners
Two questions for people with stock mount location BBCs.
How tall is your intake manifold from the intake seal to the top of your aircleaner?
What kind of hood are you running and how much space do you have between the two?
Thanks.
Old Feb 22, 2012 | 08:32 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: Big Block Owners
13'' inches, big block style hood about 2.5" rise, and about a 1/16th to an 1/8 of space between the top of the cleaner to the bottom of the hood.Name:  100_0955-1.jpg
Old Feb 22, 2012 | 08:43 PM
Parasoth's Avatar
Engine: LS1 / 455
Bingo.
My tunnel ram setup should be about 12-13 inches and seems will fit under even a 3 inch cowl. It's a Holley Pro-Dominator Tunnel Ram converted to EFI, gonna get a 4150 top for it and use two Accel 1200CFMs. They are only about 3.5" inches tall and the intake is 8.5"
Thanks a bunch 92 BBC Z.
Old Feb 23, 2012 | 08:37 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The BBC has to be the best looking engine ever made. Amazing. If only there was a way to fit one under a stock hood for a stock look.
Old Feb 23, 2012 | 11:06 PM
Parasoth's Avatar
Engine: LS1 / 455
Judging from here you would need a 10-11" setup to fit it just snugly.
If you converted to EFI and used a short TB instead of a carb I could easily see sticking one under a stock hood while using a single plane and making great numbers.
Most intakes seem to be about 6-8 inches tall, and the two EFI TB i've checked out are are 3.5" tall.
The problem most people have is a carb is about 7 inches tall. That extra 3.5" inches is where cowl hoods are needed.
Old Feb 24, 2012 | 06:30 AM
92 BBC Z's Avatar
I believe I could fit a BBC in with a stock hood without to much fuss. Would require a shorter intake, like a Performer, or another type of single plane. By the way Parasoth, I forgot to mention that the current motor is a standard deck(9.8) but I added shims(washers), about 5/16, to the engine side of the mounts to try and mimic the installed height of a tall deck(10.2), cause thats what going in next. Furthermore, there's a 1" carb spacer, and get this, a 3.5 aircleaner spacer underneath the drop base cleaner(needed for throttle clearence). Not to mention the aircleaner itself is a couple of inches thick. Hell, if I were to remove all that and go with that Spectre low fit with those side filter's, it'll probaly close with a stock hood. Of course thats just eyeballin'.
Old Mar 2, 2012 | 08:04 PM
ChristianZ28's Avatar
Car: 82 Z28
Engine: broke SBC
Transmission: 700R4, 2800-3000 stall
Axle/Gears: 7.5...,4.11..till it explodes
hey 92 BBC Z is that air cleaner open at the back,like a open cowl air box ? If so who makes it and where you get it?
Old Mar 3, 2012 | 09:23 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
very nice install......
Old Mar 4, 2012 | 07:57 AM
92 BBC Z's Avatar
Thanks man, I appreciate that, especially from another BBC 3rd gen guy. I've always admired your car, but I cant help but wonder what she would do in the "Mile" with different suspention, gears, and rolling stock? north of 200mph is my guess.
Old Mar 4, 2012 | 08:57 AM
Parasoth's Avatar
Engine: LS1 / 455
How much power are you making? A 3200 pound car needs about 800 RWHP to have a shot at breaking 200 MPH.
Old Mar 4, 2012 | 03:27 PM
Car: 82 Z28
Engine: broke SBC
The deciding factor in top speed is aerodynamics more than weight. 3rd gens only need about 650 HP at the crank to hit 200MPH.
Old Mar 4, 2012 | 04:12 PM
92 BBC Z's Avatar
Old Mar 4, 2012 | 04:44 PM
92 BBC Z's Avatar
Actually I was wondering about 1BADRZ28's 555. Its got the 650rwhp more than covered. Oh, and by the way, CPE's 89RS BBC, went 193mph with only 530hp @Ohio's TRC .They used alot of speed tape( no pun intended) on the front but they did it with a ZF-6 and 2.94 5th gear. I have a pic of the car doing this but my scanner is broke, so I'll do my best, with what I have. Wait for it.
Old Mar 4, 2012 | 05:05 PM
Car: 82 Z28
Engine: broke SBC
I was mainly referring to a real world street car.( 3400lbs , full interior ) More to the point of Gale Banks twin turbo cars back in the 80's went 204MPH with 650HP, were my point of reference. btw very clean work
Old Mar 4, 2012 | 05:23 PM
92 BBC Z's Avatar
Old Mar 4, 2012 | 05:30 PM
92 BBC Z's Avatar
Its was this car from C.P.E(Chevrolet Performance Engineering), and The 'Keith Black' camaro that were my inspiration to build 200mph capable, street driven 3rd gen.
Thanks for the compliments.
Old Mar 4, 2012 | 11:22 PM
Car: 82 Z28
Engine: broke SBC
I remember dreaming about building my own tripple treat camaro(KB's camaro) and th e king rat 496 bigblock build up, in car craft i think. It hooked me on third gens.
Old Mar 4, 2012 | 11:38 PM
Parasoth's Avatar
Engine: LS1 / 455
... Do you guys have any proof to back up your claims?
A 4th gen Camaro and a Z06 are far more "aerodynamic" than a 3rd gen could ever hope to be.
http://ls1tech.com/forums/generation...w-many-hp.html
http://www.bangshift.com/forum/showt...to-hit-200-MPH
The second link is a good read, that last 7 MPH he needed for 200 MPH could easily have exceeded 200 HP.
Might want to rethink your goals.
Old Mar 5, 2012 | 01:08 AM
Car: 1992 Camaro RS
Are you sure the fourth gens are more aerodynamic? the Thirdgens have a pretty good Cd, the Firebird being a good bit better than the Camaro, though. Ive got no doubt a newer Vette will trump the third gen F-bodies pretty handily, though.
The 85-90 GTA had the record for stock body'd car speed record for years and years.
Old Mar 5, 2012 | 07:03 AM
Car: 82 Z28
Engine: broke SBC
When the IROC series switched to the 4th gen they found the 3rd gen formula's were slicker (lower dragcoeficiant) than the 4th Gen's. they could run 185-190 with motor's that made 475+/-at daytona. (if i remember correctly)
Old Mar 6, 2012 | 10:26 AM
92 BBC Z's Avatar
What are you talkin about?
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
