V6 to 350 Engine Swap Question.
Old Mar 4, 2012 | 04:17 AM
Shadow13's Avatar
I had a V.6 3.1L engine in my 1990 Pontiac Firebird. I am swapping to a Chevy Goodwrench 350 5.7L engine. The question I have is for the fuel system. The V6 had an electric fuel pump but the V8 has a mechanical fuel pump. What do I have to do to get it to work? Please respond as soon as possible. Any and all help is really appreciated. Thanks!
Old Mar 4, 2012 | 04:31 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: V6 to 350 Engine Swap Question.
Originally Posted by Shadow13
I am swapping to a 350
If you are running a carb then you install a bypass fuel regulator on fuel line in engine bay to drop the pressure down
to required carb pressure and not use the mach pump
Or take the EFI pump out of tank and use the mech pump
Old Mar 4, 2012 | 07:12 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
i plan on doing the same thing with a 350 that was in a GM suburban. mine is a MPFI v.6 3.1, also want in on this
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
wruiz
Aug 13, 2015 09:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
