Questions about v6 to v8 swap
Old Mar 6, 2012 | 12:51 PM
Aiinfamous30's Avatar
I have an 87 v6 2.8l automatic a4 tranny firebird It over heated and damage to the crank shaft has happened so I'm thinking it's time for a swap if I use a 305 or a 350 from the same year or newer firebird which would be easier how much would bolt straight up? Which would have less parts to replace and will my tranny bolt up? If the motor came from an a4? I've been researching all day and I've read the stickys but they don't seem to answer my in family fire bird swap questions
Old Mar 6, 2012 | 01:01 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Questions about v6 to v8 swap
i dont think a v-8 will bolt to a v-6 tranny? i could be wrong though. big can of worms. it can be done, but id get a v-8 car.
Old Mar 6, 2012 | 01:11 PM
Well the moral of the story is my mom won't let me get rid of the car so seeing as how I'm looking at replacing or rebuilding I wanna go bigger I'm just trying to figure out the easiest way...I noticed on the factory spec sheets that some model 305 and all 350s that came in firebirds also came with a4 trannys now do they bolt up is a diff question which is one of the things I'm trying to figure out lol btw I'm in Tampa saw you were from NPR
Old Mar 6, 2012 | 01:24 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
cool a fellow 3rd gen member in tampa! i really dont think the tranny is gonna bolt up to a v-8. i built a firebird a few years ago with some spare parts. it had a v-6 originally. we put a 305 and a th350 in it. never finished restoreing it as it was a major project. i drive it around and the first thing i hated was the krappy 1 wheel peal rearend. some v-8 coilsprings woulda helped the frontend. lol. lots of work! modify this and that. it can be done though! whats your budget? jmo, it better to start off with an iroc or something similar. make sure it has a posi. see where im going? youll be replacing everything and when its done your gonna have a firebird still. it wont be a trans am, never be worth the money. now if you wanna go drag racing at sunshine,... lol.
Old Mar 6, 2012 | 02:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
First, welcome aboard thirdgen.org.
Second, read the V6 to V8 swap sticky in the top section of this forum. https://www.thirdgen.org/forums/engi...swap-read.html It answers your basic questions, and will probably answer questions you didn't know you had.
Old Mar 8, 2012 | 07:35 PM
nicks91rs's Avatar
the tranny will not work im in the middle of doing a swap from a 3.1 to a 307
Old Mar 8, 2012 | 09:19 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Aren't v6 and v8 bell housings the same? I could be wrong on that one. I did a v6 to v8 in a 3rd gen and threw a th350 behind it that I had laying around.
Old Mar 10, 2012 | 10:23 PM
nicks91rs's Avatar
only 4.3 have the same bell housing
$750 L98
Feb 1, 2025 02:25 PM
91 SrS
Oct 7, 2015 04:32 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
