My Engine project, more pics
Old Mar 8, 2012 | 09:40 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Mocked up on the stand and then set in the engine bay.
It fit like a glove !
Attached Thumbnails My Engine project, more pics-404335_3431772838107_1383982522_33495870_1886353448_n.jpg   My Engine project, more pics-2011-11-12-01.jpg
Old Mar 8, 2012 | 10:52 AM
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Re: My Engine project, more pics
Dang dude. Beautiful.
What all do you have in her?
Old Mar 8, 2012 | 12:37 PM
FRMULA88's Avatar
Car: 1988 Formula
Thanks,
I have owned the car since 1993, it was my daily driver for 2 years then it was relagated to "toy" status. The 383 was installed summer of 2000. it was alot of fun, plenty of passes at the drag strip and it still ran perfectly.
I sold it last fall, the 421 SBC was 5 years in the making.
with the 383 removed I dissasembled the whole front end cleaned and repainted the firewall, subframe, etc. New tubular k member, new a arms, all new suspsension, converted to manual gear box, removed the heater core and a/c delete fan box, to make some more room. New stainless steel brake lines front to rear, new rotors, calipers , New fuel lines.
new motor mounts, fasteners changed to stainless steel when feasible
The 421 has 18 degree brodix heads, solid roller cam, 12.75:1 compression, and 950 CFM Carb modified to run E85. On the dyno we also ran the shop carb and 110 race fuel. This engine made the same power on Both.. actually made a couple more HP on E85. 656 HP not too shabby for a street / strip car. I can pick up some more HP going to bigger CAM but then it's a full time race car.
Old Mar 8, 2012 | 12:50 PM
In my book 650HP is a success however you look at it. (I presume that's at the wheels so..around 720hp at the crank.)
Old Mar 8, 2012 | 01:04 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Wow. Very nice! Makes me think my car is junk.
Old Mar 8, 2012 | 01:09 PM
FRMULA88's Avatar
Car: 1988 Formula
Dynoed on a stand... engine was not in the car.
But my guy's dyno is very conservative.. the sign on the yno room door reads "NO CRY BABIES"
We did it to run the motor, break in the cam, set timing, baseline power curve. check for leaks, etc.
I am in the ballpark but there will be some fine tuning for sure. most likely just the carb jetting.
The timeslips never lie, so we will see.
The 383 best 1/4 mile was 12.16 at 111.42. It was a very consistant 12 second car, on the same dyno my 383 made 465 HP
This new 421 I will be very happy with low 11s / hightens... any faster and I need to deal with more safety regs at the track and that is money I do not want to spend right now.
Old Mar 8, 2012 | 01:14 PM
That's still a stupid amount of power. Especially since you aren't using a power adder. Very nice!
Old Mar 8, 2012 | 04:12 PM
FRMULA88's Avatar
Car: 1988 Formula
190 more horspower than the 383 and I took some more weight out of it.
amazing how all the little stuff add up...
the tubular k member and a-arms weigh almost half the OEM did
The power steering box is another dead weight compared to the manual unit, which is about half the weight.
not to mention the hoses, pump, and the serpentine brackets. the 383 also had iron heads the Brodix units are aluminum.
I was weighing all the parts but when I realized I was removing more weight than what I started with I stopped. I probably took another 200# out of the car. which hopefully offsets the added weight of the 8 point rol cage. I will weigh the car when I am finished.
I will say not having the A/C, heater, blower motor, and power steering really freed up some room in the engine bay. I refuse to gut the interior though, at that point it just looks like another race car.
Old Mar 8, 2012 | 04:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Beautiful work. Wish I had the time and patience to do likewise. Kind of embarrasses me to bring "Ugly Betty" out when you guys are around.
On the other hand, "Ugly Betty" can make me pretty proud as well. See the performance details of Berlinetta #1 with the untuned LS1/4L60E in my vBGarage.
(the "bests" came on this run)
Old Mar 9, 2012 | 11:56 AM
FRMULA88's Avatar
Car: 1988 Formula
"Pretty don't make a car fast, but fast do make a car pretty"
Personally I like both, when it's not a daily driver you can take the time doll it up.
Old May 24, 2012 | 08:02 AM
FRMULA88's Avatar
Car: 1988 Formula
progress, almost ready to run !
Attached Thumbnails My Engine project, more pics-2012-05-22-01.jpg   My Engine project, more pics-2012-05-22-04.jpg   My Engine project, more pics-2012-05-22-03.jpg
Old May 24, 2012 | 01:55 PM
85_ZED28's Avatar
Car: '85 Z28
Nice!!
Old May 24, 2012 | 02:47 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Im in the planning stages of doing a 427ci sbc with brodix 18 degree heads for my 86, similar to yours, but pump gas. Already have a block, crank and rods. (Dart Little M, Callies and Crower) Who makes those headers?
Old May 24, 2012 | 03:26 PM
FRMULA88's Avatar
Car: 1988 Formula
Headers made by Dan Lemons, located in Paso Robles, CA. They have a website just search for "Lemons Headers". They are NOT cheap but if you are committed to build a 18 degree head engine you know this already.
Stahl also makes spread port 18 degree heads, they are little less expensive but I did not like the fact you have to notch the wheel wells to get # 7 #8 to fit. You also cannot use power steering with the Stahl headers.
Old May 24, 2012 | 03:30 PM
FRMULA88's Avatar
Car: 1988 Formula
Anyone know of a good cleaning agent to use for the coolant over flow and washer pump reseviour?
I was thinking to make a bleach / water solution and soak them for a few days in a 5 gallon bucket,then rinse with a pressure washer.
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
gta90
Sep 15, 2015 04:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
