engine pull help
Old Mar 19, 2012 | 10:54 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
engine pull help
I was trying to pull my motor the other day and I took the bell housing bolts out and unbolted tne motor mounts and the motor wouldn't come off the tranny ? Its the t5 is there somthing else I have to do to get it off ?
Old Mar 19, 2012 | 11:41 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: engine pull help
I would suggest that you unbolt the T5 from the bellhousing and drop the T5. Once you do that, the bellhousing will come right off and you'll be able to pull the motor. There's enough friction between the T5's input shaft and the clutch disk splines that you're never going to be able to separate the motor from the trans with the trans still in place.
Old Mar 19, 2012 | 12:43 PM
kill4thril's Avatar
Engine: 355ci
Ok thank you
Old Mar 19, 2012 | 01:38 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Next time just pull them together, it's so much easier.
Old Mar 19, 2012 | 03:31 PM
Jim85IROC's Avatar
That's a matter of opinion. I think pulling them together is a pain in the ***. Dropping the trans out the bottom is only 5 minutes more work than keeping them together, and it makes the actual engine extraction a lot easier.
Old Mar 20, 2012 | 12:32 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's advantages and disadvantages to both ways but I always recommend to pull the tranny before pulling the engine.
Old Mar 20, 2012 | 02:49 PM
I guess I'm the minority here, than.. lol
I've done it both ways and I prefer both at the same time, I guess you'd have to pull them with/without and make your own decision.
Old Mar 20, 2012 | 02:56 PM
Jim85IROC's Avatar
That's how I learned.
Everybody advocated pulling them together, so on my father's Mustang that's how we did it. Getting the combo to tilt enough to get the motor up above the radiator support without smashing the trans into the firewall was a pain in the ***, then I still had to deal with taking the trans off the motor while it was swinging from the engine hoist. A week later when the motor/trans came back out of my IROC, I went back to my old ways of pulling the trans first.
Old Mar 22, 2012 | 10:36 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
I usually lift the rear of the car (place it up on ramps) and the motor slids right out, no problem... Stone
Old Mar 28, 2012 | 08:54 PM
torque_is_good's Avatar
if you have a service lift and tranny jack then take the tranny out, then lower car and remove engine
If you're doing it in your garage and only have jack stands, yank em both together.
I've never had any issues with raising the engine and tilting it
And it's so easy to remove the tranny from the engine. A tire laying on the ground, lower the hoist until tranny is on the tire, unbolt, done
no falling tranny
But, bear in mind that i have a very large cherry picker which has a long extendable boom and goes high when needed
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
