Lt5 head swap??
Car: 1992 camaro rs
Engine: 350 tbi
Lt5 head swap??
Not sure if this is the right Place for this but was wondering if any one has ever seen or heard of lt5 heads being put on a l98? I've always wanted "hemi" style heads on my l98 and this is the closest I can find that are readily available at a decent price
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Lt5 head swap??
I have a 90 ZR-1 and I can assure you that it is impossible. Dominion used to make 4 valve heads for a SBC but I haven't seen a set in a while.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Lt5 head swap??
Nothing on the Lotus / Mercury made LT5 block interchanges with a SBC except the GM badge
WHY.???
Don't you think if it was a worthwhile swap more guys ( esp racers ) would be using them
$10 ,000 for ARIA heads
or ARAO
http://www.araoengineering.com/Chevy/chevysmb.htm
If you buy a LS engine you can have hemi heads
http://www.yellowbullet.com/forum/sh...80&postcount=1
FOR $19,000
Car: 1992 camaro rs
Engine: 350 tbi
Re: Lt5 head swap??
I'm sure there is probably a way to make it work
Oh and why you ask...well why is the sky blue?...I want to because I can and don't care if someone is apposed to my ideas, I think it would be cool as hell to have the hemi look with my L98 plus hemi style heads give a pretty decent power gain if you don't want to run a blower, oh yeah and racers don't care about having hemi heads cause they prefer a supercharger but I'm not looking to add that much power right now
Car: 82 Z28
Transmission: T400
Re: Lt5 head swap??
Get your credit card out then
Can do it with std 23 degree SBC heads ; HEMI heads not needed
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Lt5 head swap??
You would be better off swapping in a junkyard late model hemi motor. And even that doesnt make sense other then the "because it is different" arguement.
Re: Lt5 head swap??
Not many people remember that the hemispheracle design was a chevrolet design and they saw it was going to cost a ton to develope so they sold it to dodge. Dodge made hemis back in the 50s I know and possibly the 40s. The mopar bunch like to brag that the hemi is the king of the muscle car era which it wasn't but the idiots don't realize that they are praying to the chevrolet god. Actually the Buick stage 3 grandsport turned in the best times of all the muscle cars from 1970 back. Back to the hemi question. In 1998 I saw an advertisement of sbc heads that were 4 valve hemi design made by a company called dominion. I think the cylinder head had a specific name but I can't remember it but the company name was Dominion. I have an extra LT-5 block, plenum, two heads, crank, rods and pistons, plenum, fuel rail with injectors but none of it will interchange. There is a factory, purple third gen with yellow flames that has a LT-5 in it with the ZF six speed. My LT-5 heads flowed 305 CFM with the factory 390 lift cam. The ZF six speed is about the best gear box they ever made.
ambainb
Apr 25, 2016 09:21 PM
