Time to get the camaro pushing some HP! need help.
Old Apr 29, 2012 | 11:49 PM
92z28rockinmaro's Avatar
Hello everyone, I was wondering if a 496 motor would fit on the regular camaro motor mounts. also i would like to know which in the long term is better, just to get a smaller motor pusing more horse power or any of the ls series? let me know. and where should I get parts.
this is for a daily driver.
Old Apr 30, 2012 | 09:40 AM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Time to get the camaro pushing some HP! need help.
If you want a higher horsepower motor and it be a daily driver lsx would be the way to go. Power is easy to make and they get pretty good fuel economy.
Old Apr 30, 2012 | 05:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are stickies in the top section of this forum on both BBC and LS swaps. You should spend some time going through them. I know it is a lot of reading, but it'll take you less time to do read through them than it will to do either swap, and you'll have to live with the results of the swap for a lot longer.
I've never had a big block bigger than 401 cubes, but I can't imagine needing more power for a DD than an LS1 produces. It's easy enough to get in trouble with stock LS1 power (even with the 8% power loss at mile high altitudes). The LS will also get much better fuel economy (even if you don't think you care about that), and the lighter weight will allow for better handling. And, you don't need a cowl hood for an EFI LS (and you will for a carb'd BBC).
There is adequate aftermarket support for either swap, but I'd say the LS aftermarket eclipses the BBC aftermarket (in the 3rd gen DD market, at least).
Old Apr 30, 2012 | 06:57 PM
wolfy692005's Avatar
Car: 82 z28 pace car
Engine: 383 in the works
Transmission: on the fence
Axle/Gears: 3.23 posi rear disk
I was trying to get the links in the BBC swap sticky to work and i couldnt.. is there something i am doing wrong?
thanks
Old May 1, 2012 | 10:39 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've had the same difficulty viewing that sticky, but reading a few of the 454 threads covers most of the same stuff. I disagree about the 8% at mile-high, the weight of air at sea level is 14.7 pounds per square inch, at my elevation, of 4400', it's closer to 12.45. So that's 84.7% of 14.7, so there I'm losing 15.3% of my oxygen and 15.3% of my compression. How am I not losing 15.3% of my power? You can bolt a 496 onto 305 mounts, no problem. Cubic inches are very fun if you're daily-driving, especially with a modest cam, tall gears and a tight torque converter. But you can't enjoy driving you can't afford to do. So find an LQ9, do a modest cam, do a 3000-stall, and enjoy!
Old May 1, 2012 | 01:43 PM
five7kid's Avatar
Don't want to derail the thread topic, but the effect isn't linear. 8% is probably a wee bit of an exaggeration, even. http://www.nhra.com/competition/altitude.aspx Used to be 8%, but they adjusted the correction factors recently.
As for parts sources, TGO sponsor Hawks Third Gen can handle pretty much all of your LS needs. I got my mounts, crossmember, and headers from them.
Old May 1, 2012 | 11:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Spent the last hour just thinking, and my conclusion is your 8% figure is accounting for effectively-reduced aerodynamic drag. Still a net loss of performance as elevation increases.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sonu1975
Aug 11, 2015 08:38 AM
Rustyweb7
Aug 9, 2015 03:05 AM
