can i put this corvette engine in my 88 trans am
Old Jun 29, 2012 | 02:50 PM
Muggs89's Avatar
Engine: 305 TBI
http://chicago.craigslist.org/chc/pts/3076847022.html
i was wondering if i bought this, would it fit without modifications and alot of new parts.
my old 305 is currently about to go out so i want to upgrade my 88 trans am.
does it seem like a good deal if i talked him down a little and how would i know for sure if this thing will run good and strong because ive allready had problems with buying peice of crap engines, thanks
Old Jun 29, 2012 | 03:49 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: can i put this corvette engine in my 88 trans am
Seems like a fair deal, but you still have the low-performance exhaust system and the low-pressure fuel system, both of which need upgraded. Then you have a TBI-to-TPI swap. Plenty of threads about that.
Old Jun 29, 2012 | 04:18 PM
Muggs89's Avatar
Engine: 305 TBI
how much are we talking?
Old Jun 29, 2012 | 06:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What can you do yourself and what do you have to pay a shop to do?
Old Jun 30, 2012 | 12:55 AM
Muggs89's Avatar
Engine: 305 TBI
My guys gonna cut me a hell of a deal and charge 350 to do a swapn but im sure thats not including mods
Old Jun 30, 2012 | 02:08 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Just upgrade your exhaust or else it will choke the hell out of a 350
Old Jun 30, 2012 | 08:12 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Figure at least $700 in parts for an all-new, decent exhaust system. Fuel system is just dropping the tank, swapping the pump, reinstall, then connecting the other end to the engine. Installing an all-new exhaust system is easy. Removing the original is not.
Old Jul 1, 2012 | 10:07 AM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
welcome back atilla, how are you feeling?
Old Jul 1, 2012 | 10:13 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Originally Posted by MassD
welcome back Atilla, how are you feeling?
Thanks! I'm deep-down disgusted with the no-fat diet. But that's the big secret to defeating cancer. Doctors can't make any money off it, so they deny it. Good thing I found out, I'd run out of savings, and I had maxed out my available credit. But we're off topic.
Old Jul 3, 2012 | 02:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://chicago.craigslist.org/chc/pts/3076847022.htmli was wondering if i bought this, would it fit without modifications and alot of new parts.
No.
The oil pan won't fit in the 3rd gen chassis. Changing the pan will require changing the oil pump pickup. The good news is those parts from your 305 will fit.
Ditto the exhaust manifolds, but as mentioned, your LO3 exhaust would not make a happy camper of the 350.
I don't see pictures or mention of the ECM or harness in the ad. If not included, your choices are: finding an '89 ECM and harness; or swapping your TBI onto the 350.
Also, do you see that tube that goes from the passenger side exhaust manifold over the valve cover to the intake, with insulation on it? That's the EGR exhaust gas supply tube, because the heads don't have exhaust cross-over passages in them. Be prepared for some fun connecting that to whatever exhaust you end up with.
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
milk
Aug 10, 2015 06:26 PM
Leggman1
Aug 6, 2015 04:15 AM
