350 in an 86 firebird?
Old Jul 27, 2012 | 08:56 PM
kevin j's Avatar
Car: 1986 firebird
Engine: 355's being built it be sweet yo!
Transmission: th400 short tail
Axle/Gears: 4.11
is this a tough swap or can it be done fairly easily?
Old Jul 27, 2012 | 09:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 350 in an 86 firebird?
it has the same exact external dimensions and bolt locations as any other gen 1 chevy small block v8, so it will bolt right in place of a 305 or any other chevy small block v8. The induction system, carb or FI will have to be tuned for the larger engine.
Old Jul 27, 2012 | 09:55 PM
1gary's Avatar
Don't know if this would work.But if you wanted to keep it all Ponco,a 455 would be too kewl.
http://www.enginebuildermag.com/Arti...xcitement.aspx
Old Jul 27, 2012 | 10:07 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
I have seen a couple cars with pontiac V8's swaped in. So it has been done but i don't think it's a very popular swap
Old Jul 28, 2012 | 03:10 PM
kevin j's Avatar
Car: 1986 firebird
Axle/Gears: 4.11
sorry a little more info i have the t5 already in it so i kinda want to go with the csb. currently i have the lb8 (2.8L) and im already aware that i need new motor mounts, but whats the deal with the emissions ( i want to drive the car to the track so must be street ready) what would i hav to change out and so on?
Old Jul 28, 2012 | 03:15 PM
Besides the engine:
Mounts, bell housing, flywheel, clutch, transmission, exhaust
Don't know "the deal with the emissions" in your state... never lived there... can't help you there unfortunately.
Old Jul 28, 2012 | 03:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i didnt notice you had a v6. You need motor mounts, which is no big deal
you will not be able to use anything from your current engine, or trans. You will need everything, including the bellhousing and trans from a v8 car.
you will need the wiring harness as well from a v8 car to do a factory install. If its a basic, non emmisions legal carbed v8, you can make do without.
Old Jul 28, 2012 | 10:58 PM
kevin j's Avatar
Car: 1986 firebird
Axle/Gears: 4.11
i have the trans bell housing clutch and fly wheel from the v8 Camero (same year) so all i need is motor mounts and obviously a new exhaust?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
theshackle
Mar 5, 2017 06:37 PM
theshackle
Aug 22, 2015 06:52 PM
