305 tpi to 350 tpi
Old Oct 10, 2012 | 02:18 PM
speeddemon86z28's Avatar
Car: 86 Iroc-Z, 92 Firebird Formula
Engine: 350 carb, 305 TPI
Transmission: T5, T5
305 tpi to 350 tpi
Hey guys, I've got a 92 formula 305/T5. The 305 just recently crapped out, and instead of rebuilding it, i'd rather just put a 350 in the car. To be honest this is my first car I've ever owned to have something different than a carb. At the restoration shop I work at, we strictly only work on older Chevrolet muscle cars. Nothing with fuel injection. So I just want some advice before I dive into this. After doing some reading, it looks like I will need 22 lb injectors instead of the stock 19 lb injectors. I was thinking I could change the injector size in the PROM, not sure though. You guys can tell me if i'm just crazy on that. Either way, I would rather have the bigger injector in there. I noticed the knock sensor looked the same..is it? I am assuming that it is NOT the same. Also, I am somewhat confused about the ESC module. I read that the ESC module is contained in the PROM on the 90-92. If this is true, than I won't need to worry about it if the new 350 is a 90-92, along with the PROM. The ECM looks somewhat universal between the two motors, I just have to get the correct year for the motor. The PROM is confusing to me, I know it all depends on the ECM type and the transmission that I will be using. I will be keeping my T5, however it will be getting rebuilt, as its completely shot. Iv'e read a little about beefing up a T5, that'll most likely be my route. I'd love a t56 but I don't have the money. I know the accessories will all work, so i'm not worried about that. So if you guys can help clarify these things with me, that'd be great. I know I don't have much posts, but I have done a ton of reading on this site and it's really a great site. Thanks guys!
Old Oct 10, 2012 | 02:19 PM
Re: 305 tpi to 350 tpi
Also, if there are any tips/tricks/things I should know that would make this swap a lot easier...that would be great. Thanks again.
Old Oct 12, 2012 | 12:27 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
The actual motor swap is no more difficult than falling off a bar stool. The tuning, as you've realized, is the problematic part. The learning curve is pretty long and kinda' tricky. My advice would be is if this is going to be a one shot deal, find a competent tuner and take it to him. If you're hell bent on DIY, there's a wealth of knowledge on this board. However, you can't be impatient/lazy/a technodunce... like me!
Old Oct 12, 2012 | 12:38 AM
Yes, well i'm sure several guys on the board have done this exact swap. I searched for exactly what I did, and didn't find much luck. Maybe i'm not doing it right? I have found other sites to have some help/advice but not explaining things as well as this site usually does. I know the motor swap itself is pretty easy, I have already had the motor out of the car once, and I know the 305/350 both bolt right in. I'm not worried about that as much as all the electronic "stuff". I'll be honest, I do not know where to begin with the tuning etc, like i said earlier, never owned anything but a motor with a carb on it...and thats what i'm comfortable with...however I would love to complete this, and gain a little more knowledge about my car as well. I love it.
Old Oct 12, 2012 | 12:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I was thinking I could change the injector size in the PROM, not sure though. You guys can tell me if i'm just crazy on that.!
You could retune for smaller injectors ( not recommended ) but larger injectors are installed by the factory for a reason
Electronics are straight swap like for like but you need a 350 TPI (90 - 92 MAP ) knock sensor and a 350 TPI (90 - 92 MAP ) memcal ( prom)
Same '730 ECM used in both the MAP 90 - 92 305 /350 and wiring identical so you need nothing new
Engine has no idea what is controlling it and ECM has no idea what engine is under the intake so years irrelevant.
What matters is that you have the correct combination of ECM / wiring /sensors required for what ever setup ( in your case MAP ) you are installing ;
plus the parts unique to a MAP 350 noted above
Auto tune (on the memcal ) has provision for the convertor lockup so you could use a auto memcal on a man but not a man memcal on a auto
Old Oct 18, 2012 | 09:40 PM
lettuce's Avatar
Car: '86 iroc
Engine: 305 tpi
Axle/Gears: 2.73? whatever is stock
I am also looking into a lb9 to 350 roller swap keeping the tuned port stuff like a L98 however my LB9 is 86. Can I run it with an 87 L98 computer and, of course, the bigger injectors and 350 knock. Did the 87 L98 use the maf too? Or am I gonna have to do major electronic mods? I assume a chip company can tune through chip right?
Old Oct 18, 2012 | 09:51 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
yes 22-24# injectors
Old Oct 18, 2012 | 10:47 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
All TPI computers are identical regardless of engine size
ECM # '165 for 86 - 89 MAF or ECM # '730 90 - 92 MAP
It is the tune on the removable chip / prom / memcal that determines what it is set up for which is why you need a 350 memcal when doing the 305 - 350 swap
You swap engines , reinstall your TPI intake , connect existing wiring , install the required 350 items noted above and drive off
Old Oct 19, 2012 | 03:20 PM
lettuce's Avatar
Car: '86 iroc
Engine: 305 tpi
Good deal. Sounds pretty straight forward. Thanks for answering that question for me. I will write down all the details.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
