HOOD WONT CLOSE WITH BREATHER ON
Car: 86 firebird
Engine: 5.7
Transmission: currently T350
Axle/Gears: stock for 2.8 V6
getting close to completion of 2.8 to 5.7 swap on my firebird but realized that the hood hits the breather when its on the carb I'm using an eddelbrock chrome breather basically a base and a cap with the filter sandwiched between and its holding the hood up about 2 inches any suggestions?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HOOD WONT CLOSE WITH BREATHER ON
JamesC
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
What carb are you using? What intake? If it is a Holley carb, I would recommend the reproduction of the L88 drop base air cleaner. This, combined with a 3" tall filter element and a generic chrome lid easily fits under my IROC hood with an RPM Airgap intake. The aftermarket drop base air cleaners that I have seen do not provide as much room as the reproduction L88 base.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I would go with the re-pro L88 bass as pan stated.
Car: 86 firebird
Engine: 5.7
intake stock cast iron carb is holly not sure on model but its a duel feed was considering cutting a hole in the hood and a hood scoop. Also this is a 4 barrel carb with an adapter plate about 3/4 inch thick.
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
A cowl hood will clear and give it fresh air. You can run a tall intake and whatever air cleaner you want. I personally like those 67 corvette BBC stinger hoods they offer for our cars.
Car: 1990 IROC
Save the money on the hood and scoop you don't need and buy the intake you do need.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
