v6 to 350 swap sensor help
Old Oct 22, 2012 | 09:32 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i just swapped from a 2.8 v6 to a 96 l31 350 and i need help with the sensors, i cant find where my oil pressure sensors go for the gauge and the safety switch. help? the sensors themselfs are too small to fit into the hole above my oil filter like my old v6, where in the hell do these sensors go?
Old Oct 22, 2012 | 09:40 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: v6 to 350 swap sensor help
Right behind the intake manifold, at the top center of the engine.
Old Oct 22, 2012 | 09:54 PM
Engine: L31 350
do both go there?
Old Oct 22, 2012 | 10:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
You should be able to just get a single one that has both in it from a newer car.
Or you run a short male pipe up to a T then put each sensor in it.
Old Oct 22, 2012 | 10:21 PM
Engine: L31 350
where can I get the t? I have two new sensors I want to use
Old Oct 22, 2012 | 10:23 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Usually auto parts stores will have a small selection of brass fittings, 1/8NPT is what you need, also home depot, lowes, etc have them.
Old Oct 23, 2012 | 01:35 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
help?
Do you ever read the replies left for your questions ?????
https://www.thirdgen.org/forums/engi...-location.html
do both go there?
Old Oct 23, 2012 | 01:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the sensors themselfs are too small to fit into the hole above my oil filter?
If they are "too small " then one is sure to fit in the 1/8" NPT hole in the block under the dist
but depending on the style of sender you have ,you may need a extension piece or right angle adapter
so sender clears the intake manifold .
Some of the factory OEM senders have longer " noses " to extend them out from obstructions
http://www.motorcityreman.com/gemooe1028.html
The other " too small " one will fit in the hole above the filter with a 1/4" to 1/8" NPT reducer
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
