Vortec alternator mounting options
Old Nov 4, 2012 | 02:37 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Got my motor installed and ready and found out that the brackets I got off an 87 firebird 305 tpi won't work, I found a didn't set off a camaro tpi, will these work or do I have to get a set off a tbi? I'm running a carbed l31 cortex motor with an eldebrock proformer intake, what have others done for alternator mounting brackets?
Old Nov 4, 2012 | 02:45 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Vortec alternator mounting options
I used my 92 TBI brackets on my vortec heads... no issues. Why is it that yours wont work? As far as I know Vortecs have the same mounting holes as every other 1970+ sbc head.
Old Nov 4, 2012 | 03:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You forgot to mention you are using a V6 ALT , is it identical to a V8 one
( that should fit )
Old Nov 4, 2012 | 04:19 PM
Engine: L31 350
right now I'm trying to use a the brackets from an 87 firebird tune port injection and there isn't any adjustment length for the upper bracket. So I found a complete bracket setup for a camaro and the upper brackets look longer, also note I'm using v belt brackets. Can you post pictutes up of yours please?
Old Nov 4, 2012 | 04:20 PM
Engine: L31 350
( that should fit )
I have a v6 and a v8 alternator here and while the v8 one fits there isn't enough room for the upper bracket to mount and I don't have the correct plug for it.
Old Nov 4, 2012 | 05:07 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Got some pics so we can see your problem?
you can buy conversion plugs
Old Nov 4, 2012 | 10:22 PM
Engine: L31 350
ill try and get a pic tomorrow after school, i have the alternators out of the car. and where can i get the conversion plug? autozone or another after market dealer?
Old Nov 5, 2012 | 06:17 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
What type ALTs are they?
You can get plug in harnesses to adapt old style GM SI ALT to later style CS series ALT ( 130 or the larger 144 used on LT1's )
See
http://forums.corvetteforum.com/1575500651-post4.html
Old Nov 5, 2012 | 08:47 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i bought this cheap, chrome bracket at a speed shop. sorry, i doubt i have a part number. i used most of the factory 87 brackets, belts etc. its half v-belt and half serpentine. i might be able to get you some brackets, pulleys, etc., if needed. a friend of mine passed away awhile ago and was building an 87 at the time. his wife has been selling stuff lately. heres a few pics, hope it helps.
Old Nov 5, 2012 | 06:52 PM
Engine: L31 350
I like this, I saw something like this in my summit catalog today actually, and all I need are the brackets and a good alternator.
Old Nov 5, 2012 | 06:54 PM
Engine: L31 350
See
my plug is ci. The 2 prong type and the v8 alt I have is the larger style
Vintageracer
Jan 10, 2020 05:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
Cleotiz
Aug 23, 2015 12:07 PM
guy76767
Aug 6, 2015 05:58 PM
