2.8l to 3.8l supercharged
Old Nov 9, 2012 | 04:27 PM
countryboy1369's Avatar
Car: 1988 Camaro SC
Engine: currently 2.8lv6
Transmission: 700r4THM
I want to swap out my stock 2.8 for a 3.8 supercharged. dont know much about it and need some suggestions. what would be the best motor, will it bolt direct or do i need modified mounts, what can i expect as far as power difference? etc.
Old Nov 11, 2012 | 10:29 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: 2.8l to 3.8l supercharged
I hate to be that guy but i searched on here and google and found other people doing this.
Old Nov 12, 2012 | 11:09 AM
Car: 1988 Camaro SC
i didnt say i was the only one, just that i need some help with it as i am doing it myself and am looking advice from people who may have done it before. half of what is said is gibberish to me im new to this and my automotive expertise stops when i got to go into the motor
Old Nov 12, 2012 | 11:25 AM
Car: 1988 Camaro SC
besides that link is for a 5.0ltr 305 v8 supercharged. im trying to keep it as simple as possible by swaping for a v-6 with more displacement. and hes building his motor not swaping for one already built. im looking for a stock supercharged v-6 that way i dont have to expand the fuel lines, larger fuel pump, beefed up suspension, new ecu, bigger brakes, so on and so forth. i want to keep a v-6 but with more power.
Old Nov 12, 2012 | 06:49 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
there are plenty of turbo v6 threads in the v6 forum
Old Nov 13, 2012 | 06:23 PM
Brando5641's Avatar
Did I post a link or somthing???
Old Nov 13, 2012 | 07:24 PM
Car: 1988 Camaro SC
seen a link on the bottom of your post so i followed and it led me to a 305 rebuild. thought it was a link you posted for me to look at
Old Nov 13, 2012 | 07:25 PM
Car: 1988 Camaro SC
i dont want to turbo because its an automatic. im lookin a supercharged v-6
Old Nov 13, 2012 | 07:33 PM
Car: 1988 Camaro SC
see i toyed around with the idea of twin turbo like we just did on my buddys 2.2l probe gt, but his was a manual. ive always thought turbos were better suited for a standard. if im wrong please correct me. cuz im trying to do a poor boy mod, meaning i dont have alot of money to throw at it. but im willing to spend to increase my acceleration and top end as well, and the turbo increases accel but doesnt do much to top end. besides the motor just feels too small for the car but i dont want to up to a v-8
Old Nov 13, 2012 | 11:20 PM
Engine: 5.7 / 7.4
try this http://60degreev6.com/forum/showthre...rcharger-Build
but you'd have to convert to carb or stand alone 2bb tbi
Old Nov 14, 2012 | 06:25 PM
Car: 1988 Camaro SC
the grand prix gtp is fuel injected and supercharged v-6. but if i have to switch to carburated then thats fine save. i was looking at the l32(?) out of the gtp but dont know how well it would work as it is a fwd motor. the 2.8l is as well, but it is a fwd rear mount motor so it works for front mount rwd.
Old Nov 14, 2012 | 06:30 PM
Car: 1988 Camaro SC
thanks for the link.
Old Nov 14, 2012 | 06:34 PM
Car: 1988 Camaro SC
i think ive made up my mind on the L32, but i just need to know how to go about putting it in. you know fwd to rwd bolt up to 700R4 THM, what will work and what wont
Old Nov 14, 2012 | 08:28 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
The L32 3800 and the 2.8L V6 you have should share the same bellhousing bolt-pattern. Also, if I remember what I've found in the past, even the FWD 3800 blocks should have the bosses for the RWD mounts that were on the 3800 V6's in the 4th-Gen F-body. You'll probably have to cut the inlet off the supercharger and weld on a new inlet that's more U-shaped to clear the firewall and re-route it towards the front of the car. Something like the first picture in this guy's thread:
http://www.3800pro.com/forum/rwd-380...-pictures.html
Old Nov 15, 2012 | 09:30 AM
Car: 1988 Camaro SC
thats an awesome moded supercharger. that is helpful. so in order to swap, will i have to modify the engine mounts? pretty sure i will, this is my daily driver as well so its making it harder to work on cause it has to be done in a weekend
Old Nov 15, 2012 | 11:23 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Mounts and brackets from a '96-'02 V6 Camaro or Firebird would be a great place to start. They should bolt to the 3800 block without issue. Their placement on the K-member's mounting pads is the only thing I'm not sure of. In the worst case scenario, you could probably rig up some kind of adapter plates between the mounts and the K-member. But, honestly, I don't know.
Old Nov 15, 2012 | 01:58 PM
Car: 1988 Camaro SC
thats awesome thanks. im going to look into this and when i start the swap i will be posting pics
Old Nov 15, 2012 | 02:00 PM
Car: 1988 Camaro SC
also would like to go with a posi-trac rear end, anyone know a good one to use?
Old Nov 15, 2012 | 08:45 PM
Engine: 5.7 / 7.4
i fabbeb up brackets and had welder make them for $80. I have a thread in fabrication forum showing diff between 2.8 & 3800 brackets. The new brackets went from the 2.8 mounts to the block
Old Nov 16, 2012 | 12:08 AM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
I don't think your pictures in that thread work, anymore.
Old Nov 16, 2012 | 07:41 AM
Engine: 5.7 / 7.4
http://www.cardomain.com/ride/325040...ntiac-firebird It has some pics. Gotta see if bracket pics load on notebook, they not on iphone and were working a few days ago
Old Nov 16, 2012 | 03:59 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
i think ive made up my mind on the L32, but i just need to know how to go about putting it in. you know fwd to rwd bolt up to 700R4 THM, what will work and what wont...
In my opinion, so take it like a grain of salt, stick with your 2.8, massage your stock heads, get a decent cam with lots of overlap (turbo's benefit from that), stick with your stock ECM but swap in a different chip. There is a prom out there that will install right into your MAF ECM and essentially convert it over to SD, you just need to repin a few wires and your done. Get yourself some headers, turbo, wastegate, downpipe, and from there you can focus on your injectors, stall and gears, and you will have a pretty damn fast car when your done. If you need help with that idea, bring this thread on over to the V6 section...
Old Nov 17, 2012 | 09:33 AM
Car: 1988 Camaro SC
thanks but i dont want a turbo. i want it supercharged there are only a few that have converted to a s/c 3800 and im trying to be one of them. too many people opt out for a turbo or the v-8. i want a little uniqueness in mine.
Old Nov 17, 2012 | 09:41 AM
Car: 1988 Camaro SC
according to the link to 3800 proforum there are only 3 done like this, so i definately want it in mine. combined with other modifications, but none to the body, it will be very unique.
Old Nov 17, 2012 | 06:45 PM
Engine: 5.7 / 7.4
4th gen related, but interesting read http://www.firebirdgt.com/SC%20Firebirds.htm
Old Nov 17, 2012 | 09:42 PM
Car: 1988 Camaro SC
that aint bad for the 4.3l v-8.
bplessy
Sep 30, 2015 12:14 PM
-=Z28=-
Sep 24, 2015 10:21 AM
88rscamar0
Sep 23, 2015 09:08 PM
64goatman
Sep 9, 2015 01:09 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
