motor mount help?
Old Nov 23, 2012 | 02:18 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
Transmission: BW super t10
motor mount help?
i am dropping in my 350 into an 82 camaro. swapping out the 305. I ordered the poly inserts from summit pn PTP-7-506 and i cant get them to line up. i know they are suppose to be tight but they dont even appear to line up with the holes.
Old Nov 23, 2012 | 02:53 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
Re: motor mount help?
pics might be easier, but you might have the pieces flipped around
Old Nov 23, 2012 | 05:04 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
after swapping around motor mounts i finally got everything to line up....except drivers side rear hole. the bolt is completely through on passenger side and through the first hole on drivers side but i cant get the aft hole to line up.
Old Nov 23, 2012 | 07:23 PM
Car: 86 Camaro Z28
Make sure the inserts aren't backwards either. The engine won't sit straight if they aren't right. The instructions will have the correct positions. It sucks when you find out after the engine is already in.
Old Nov 23, 2012 | 07:31 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
the metal tabs are in the correct orientation. is there any difference between left and right? from the looks of it they appear to be the exact same
Old Nov 24, 2012 | 07:54 AM
Car: 86 Camaro Z28
they are interchangeable
Old Nov 24, 2012 | 08:02 AM
Boz2882's Avatar
Car: 82 Z28 Camaro
dont suppose you have the part numbers for the engine side motor mounts that i should use
Old Nov 24, 2012 | 02:20 PM
Car: 86 Camaro Z28
just take the clam shells off the 305, or was there no engine when you got the car?
Old Nov 24, 2012 | 03:04 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
there was a 305 in it. i am reusing the original clamshells with the poly inserts. i tried reusing the part that mounts to the block and sits over the clamshell from the 305 but the holes dont line up. i even mounted the clamshell to the engine mount bracket and lowered it in that way and those holes wont line up either. the numbers on the side are 039436 from the 305 and i have a 15627282 and a 15627281 that were on the 350.
Old Nov 24, 2012 | 05:51 PM
Car: 86 Camaro Z28
are these what you are working with? the clamshell bolts to the block and the 2 pieces with the insert bolts to the frame.
Attached Thumbnails motor mount help?-oer-332648.jpg   motor mount help?-4.jpg
Old Nov 24, 2012 | 06:36 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
yes those are what i have. except the ploy insert instead of stock rubber. pita!
Old Nov 24, 2012 | 07:18 PM
Car: 86 Camaro Z28
They aren't that bad. All you have to do is thread all the bolts first, then tighten them. It's only an issue when the rest of the suspension is in the way.
Old Nov 25, 2012 | 12:58 PM
Boz2882's Avatar
Car: 82 Z28 Camaro
if i have one side of the holes lined up i cant even see the holes on the other side and if i line up te holes evenly i can only see 1/4 of the holes. i dont have any of the front suspension in
Old Nov 25, 2012 | 02:09 PM
Car: 86 Camaro Z28
flip the metal pieces around, one pair of holes is wider than the other.
Old Nov 26, 2012 | 09:15 AM
Boz2882's Avatar
Car: 82 Z28 Camaro
The holes line up when they arent on the block. I have them in the right direction. When i attach them to the block and lower it in they wont line up
Old Nov 26, 2012 | 09:45 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
I have always mounted them to the body first and then dropped in the engine and never had any problem.
I am making the assumption that since you had a 305 in there already that you are putting the new mounts in the V8 position and not the V6 spot.
The pic is of the old mount for a V8 on my 84.
Old Nov 26, 2012 | 10:12 AM
Boz2882's Avatar
Car: 82 Z28 Camaro
Yes thats where i have them. I originally put them on the frame then lowered the block in and could only get the second bolt through the first hole. The bolt was atleast an inch off from the second hole. I did notice that the bracket wasnt seated on the metal tabs rights so ill try shaping the metal the fit better when i get home tonight.
Old Nov 26, 2012 | 11:49 AM
Boz2882's Avatar
Car: 82 Z28 Camaro
I found on a different post on here that there are different pn for passenger and drivers side. The numbers i posted earlier only 039436 is for camaro, the passenger side. The other 2 are for whatever truck or van the 350 came out of. The other pn is 334971 which is for the drivers side. In the thread they argue about how usefull/useless that info is. Is it possible that it doesnt matter with the 305 but when installing a 350 with poly inserts it could mean that little amount i need to get the bolts to align?
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
