1987 t/a with 305 carb to 350 LT-1 carb
Old Nov 18, 2012 | 01:12 PM
exwife'scar's Avatar
just bought a 1970 camaro LT-1 #3970010 with 11:1 pistons just rebuilt with 2280 miles on it and wanna swap it in. Ive been reading alot of threads but don't c any on this particular swap. Basically i'm wondering is it worth the hassle and what issues i'm gonna run into b it smog, a/c, harness or frame with 350 HP I have all the original smog on the new engine and all the parts from the original 305 still in the car running, just smokes with 260k on it.......
Old Nov 18, 2012 | 05:48 PM
Re: 1987 t/a with 305 carb to 350 LT-1 carb
Every 010 block is either a "Camaro LT-1" or "from a Vette" nowadays.
Just a bunch of sucker bait to lure in people who don't already know that 010 is the single most common 70s 4" bore casting.
It's a small block Chevy. Leaving aside all the romantic feel-good weasel words, it'll bolt into one of these cars the same as any other small block Chevy. Gotta have heads with the bolt holes in the ends, otherwise you won't be able to install minor conveniences like .... an alternator. You'll need to make sure it has the bolt holes for the starter/flywheel combo you want to use; MOST 70s blocks don't have the one starter bolt hole for the pattern that was introduced in about 78 or so. If you need it and it's not there, drill it BEFORE you drop the motor in.
None of the rest of that stuff you posted about it makes the slightest difference.
As far as the "smog" stuff, what you need to do about that depends on where you live.
Old Nov 18, 2012 | 07:36 PM
it has # 3991492 heads camel hump with acc holes and i have the original starter for the new motor, specs for the cam are on my phone,,,,,,,not with me at the moment, block was bored .30 over making it a 355,,,,,,,don't understand the hp @ 350 when gm stated 4 bolt 11:1 ratio at 360 for camaro and 370 for vette stock,,,,,,,,really worried bout the frame holding up and maybe the ecm...............thanks for the input
Old Nov 18, 2012 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Same block was also used for a 165Hp truck engine
As the man said above , the block casting # means zilch this far down the track
Old Nov 18, 2012 | 08:16 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
That was under the old Hp ( gross ) rating system , would be way less under the current way Hp is measured (net Hp)
Read
http://ateupwithmotor.com/automotive...orsepower.html
Old Nov 18, 2012 | 08:28 PM
Original starter FOR THAT MOTOR might or might not fit THE CAR.
Try it before you drop it in.
Don't worry about the frame, it'll be fine. Get some SFCs anyway, it's amazing how much better they make one of these cars.
The ECM won't care, as long as the cam doesn't have more than about 220° of intake duration.
Those "ratings" don't matter; in 71 or 72, whenever it was that they changed the "ratings" system, that motor would have went to about 275 HP. But that's not what you've got, regardless; you have A REBUILT motor, so whatever GM called whatever motor made with whatever of the parts you happen to have might have come from, has no relevance to what YOURS is, NOW TODAY.
Old Nov 26, 2012 | 12:55 PM
ran car on turkeyday to find out what kind of rear it had without jacking it up,,,,,, limited slip.....then let it idle for a bit to charge batt and it died and wont start up any more....thought it was fuel filter at carb or maybe fuel pump.......took off fuel line at carb and cranked it over got fuel flowing,,,,,,,took fuel filter out at carb, blew threw it seemed fine,,,,,,,any suggestions,,,,,,,,,,,,,,,,,,all appreciated,,,,thanks
Old Nov 26, 2012 | 12:57 PM
And if your all wondering,,,,,,,,,,I traded a couch for the car during the divorce settlement
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
cRoe4
Aug 7, 2015 08:46 PM
