454 swap
Old Dec 1, 2012 | 08:44 PM
codyscamaroz28's Avatar
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
454 swap
So im wanting to do a Big Block swap in my 91 rs. ive found one a guys put in his nova, he says it came out of a 1979 chevy 1 ton truck camper special. its all stock except the intake its a ram tunnel single plane. whats the specs on the 454s in 79? would this be worth doing. ive read that my biggest issue is the headers. any tips and advise would be great appreciated. Thanks
Old Dec 1, 2012 | 08:56 PM
1gary's Avatar
Re: 454 swap
how much?
Old Dec 1, 2012 | 09:03 PM
Re: 454 swap
what do you mean how much?
Old Dec 1, 2012 | 09:06 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: 454 swap
thats the question you have to ask yourself, how much do you wanna spend, how fast do you wanna go, how much of it can you do yourself, how much room do you have?, probably not what he meant, but its what you gotta do
Old Dec 1, 2012 | 09:10 PM
Re: 454 swap
i just wanna leave it stock for now. my dad and brother will be helping me with this swap.
Old Dec 1, 2012 | 09:20 PM
kmcn47's Avatar
Transmission: 5spd
Re: 454 swap
do you already have a 454 to swap in? or will you still be needing that? if so you gotta look at what they came in and where/how you'll get ahold of one, if its been sitting for awhile (lets be honest most things form the 70s with 454s aren't daily drivers anymore) it will need some new parts if not a good rebuild, thats more money, then comes the trouble of actually fitting it in.
Old Dec 1, 2012 | 09:23 PM
Re: 454 swap
i am looking at one. it came out of a 1979 chevy 1 ton truck
Old Dec 1, 2012 | 09:29 PM
kmcn47's Avatar
Transmission: 5spd
Re: 454 swap
well like i said you need to figure out whether or not it will need rebuilt, and how much you wanna spend, i can tell you that if your car is your daily driver its really not a good idea to do this
Old Dec 1, 2012 | 09:32 PM
Re: 454 swap
it runs ive heard it run. and i plan on driving my s10 beater as a daily driver.
Old Dec 1, 2012 | 10:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 swap
In 1979, the 454 was rated at 240hp @ 3800 and 370torque @ 2800. Since no cars were offered a BBC after 1974, all the BBC engines after that came from trucks. Camper Special just means it has heavy duty suspension and brakes.
What kind of power does it make now? If it's never been rebuilt, probably less than when it was new. A single carb tunnel ram is a poor combination for power especially if nothing else has been touched.
The only good thing about the engine is that it will probably have 049 or 781 oval port heads. Do some port and polishing and install 2.19/1.88 valves and they'll be fine.
Old Dec 1, 2012 | 10:29 PM
Re: 454 swap
it sounds pretty healthy. he says its stock, low mileage. it was a farm truck. according to him anyways
Old Dec 1, 2012 | 11:07 PM
1gary's Avatar
Re: 454 swap
How much means how much does the seller want for the 454??.
Old Dec 1, 2012 | 11:20 PM
Re: 454 swap
600$
Old Dec 2, 2012 | 12:18 AM
1gary's Avatar
Re: 454 swap
Yeah-I was actually thinking $500,but that isn't too bad.
I think you need to look at this two ways.
The first is to compare what it costs to build a SBC vs a BBC. I believe the thing that drive people away from BBC's is the cost of aftermarket overheads,heads,cam and kit,intake/carb.Mostly the cost of decent aftermarket heads.The smog O.E.M. heads aren't worth much. What really wakes up these 454 is a decent set aftermarket of heads and cam/kit.The pistons/rods cost compared to a SBC isn't significant.A 454 crank can get pricey when you start going into stroker cranks,but to get a good 454 forged crank isn't that bad.
Then the second thing is to compare swap costs.Neither the 700R4 or the T5 will hold up behind the 454.The 7.5 rear isn't up to the task either.The headers are certainly going to cost more.Then the cooling system is going to need mods for the 454. So let's ballpark a 454 swap costs.Conservatively $3,000 to $5,000 grand.That would be for a 9" Ford rear end,gear set,posti,engine mounts,headers,mods to the 700R4,cooling system mods,frame connectors, maybe hood mods depending on which induction you choose.
Are you going to escape those costs with a SBC??. Well not totally. Lets say about haft of it.
To have your head wrap around $3000 to $5000 in any swap would be good starting point.And be willing to be flexible in that.
Anytime you think about going cheap during the swap,go over in the corner of the garage,take off your shoe,and abundantly hit your big toe with a large hammer.You will decide very quickly that isn't a good idea. LOL
Old Dec 2, 2012 | 01:51 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: 454 swap
^ that's a conservative number assuming everything goes perfectly and you don't run into issues. I'd be expecting more than that, IMO. That's just me, though.
Old Dec 2, 2012 | 09:45 AM
1gary's Avatar
Re: 454 swap
no.your right.
Old Dec 2, 2012 | 10:45 AM
Re: 454 swap
So, after reading the EXTENSIVE "sticky" at the top of this forum, are there any SPECIFIC questions you have, that AREN'T ALREADY ANSWERED?
Old Dec 2, 2012 | 01:48 PM
Re: 454 swap
my question is, how much is it gonna cost me to do this swap.. what do i got to buy on top of buying the motor?
Old Dec 2, 2012 | 04:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 454 swap
Technically, headers but by the time you've completed the swap, it may have cost you a few thousand dollars.
The BBC will fit in the same place that a SBC will. There will be a couple of hookup issues such as coolant lines, electrical connections etc but that's to be expected with any kind of swap.
If you don't already have it, an electric fan should be used as the BBC tall water pump won't leave a lot of room for a mechanical fan.
Hood clearance is always an issue unless using a low profile manifold and drop base air cleaner.
If you want to do the swap, then jump right in and do it. Don't expect any kind of foreign engine swap to be an easy drop it in and go type of swap. Nobody can tell you exactly what will need to be changed because each swap is a little bit different. The more complete the swap engine is such as alternator and power steering mounts, the easier the swap can be.
If you're not willing to adapt or modify to get something to work then just stick with a SBC.
Old Dec 2, 2012 | 04:37 PM
Re: 454 swap
If there's still a guy named Steele that owns a body shop in your part of the world (haven't talked to him in a decade or more so I'm not sure) go talk to him.
Old Dec 8, 2012 | 08:10 AM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: 454 swap
What you need is a plan. What do you plan to do with the car? If all you want is a camaro with a 454 then like AlkyIROC said, "technically headers". But if you plan to put that car under stress, meaning ANY kind of competition,be it drag racing, road racing, street racing, cone cutten', drifting, dyno-pulling, or even a simple burn-out contest, your going to have to spend some $ to strenthen the chassis, and suspention. 79 1-ton, anything about that truck that says, week, light, or not up to the task. No. But a 3rd gen is not up-to that task with just as factory equipment.
Old Dec 17, 2012 | 05:24 PM
ChristianZ28's Avatar
Car: 82 Z28
Engine: broke SBC
Transmission: 700R4, 2800-3000 stall
Axle/Gears: 7.5...,4.11..till it explodes
Re: 454 swap
I had a '79 Bu with factory 454/4 speed. Last of the big block bu's. Would love to have that one back!
Old Dec 19, 2012 | 12:38 AM
thegreasemonkey's Avatar
Re: 454 swap
from the progress and research ive done you'll need an aftermarket k-member, a set of headers, and some kind of cooling system and accessory drive. im doing this swap on my 91 rs and i am moving the radiator forward an inch or two to free up some room (not gonna run a/c). i plan on ordering the k-member here soon. ive got almost 2000 in my motor already and i have'nt even finished it yet so it depends on your budget oh and depending on your intake setup youll probably need a 4 inch cowl hood to clear the carb and aircleaner
Old Dec 19, 2012 | 10:00 AM
1gary's Avatar
Re: 454 swap
It would be a really bad idea to swap the engine in and then later decide you want aftermarket heads/cam and kit.Tight spaces makes this so.Those smog heads ant that good.It is a equally bad idea to go through all the work to swap it in and not reseal/rebuild the engine.If that has never been done before,it is what,a thirty yr old engine with untold number of miles.
My point here is you have thousands invested with a high risk high mileage engine and if it takes a drive,you lose it all.
Old Dec 19, 2012 | 10:22 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 454 swap
Stock K member and motor mounts will work.
Hooker headers are your cheap option, Ed Quays are the good ones.
Even with a dual plane intake you will not have hood clearence for an air cleaner, so a cowl hood will be needed.
Might as well delete the ac now if you want to change your plugs. Power brake booster is close as well.
The engine in question probably doesn't make any more hp then what you have now, but some more torque. It has about 7.5:1 compression, so its pretty tame.
You are going to be adding over 100lbs to your front end. It will not handle the same. Get HD springs and new struts.
A trans swap. That t 5 wont last a week behind a BBC.
All and all, for a street car, a bbc swap is a waste of time and money.
If you are going heads up racing, thats another story.
Old Dec 20, 2012 | 09:17 PM
Re: 454 swap
just curious but what oil pan are yall running to clear the k-member the guy i talked to told me he had to modify his stock pan and k-member to fit
Old Dec 20, 2012 | 11:49 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 454 swap
All good things to consider
Some headwork and a cam it will really wake up
Throw that tunnel ram in the trash or sell it they arent worth a damn on the street.
Old Dec 21, 2012 | 07:40 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
Any factory car pan should work.
I ran this
http://www.jegs.com/i/B-B/128/91488/...oductId=746460
Old Jan 2, 2013 | 01:54 PM
92 BBC Z's Avatar
Re: 454 swap
Pan clearing the k-member shouldnt be much of an issue, but if you go with a kick-out style pan(its what i used, i wanted/needed the extra capacity, without sacrificing ride height with a deeper pan) you might encounter header clearence problems, I did, but I handle it. I dont usally shop for hi-performance parts that fit 3rd gens, I shop for the best, then make it fit.
Old Jan 3, 2013 | 08:06 AM
1gary's Avatar
Re: 454 swap
John-is the lady in your car's passenger seat 100lbs or more??. Got extra springs/struts under her??.
Trust this old guy,don't tell her she has to get out because the car doesn't handle the same.
Old Jan 3, 2013 | 09:22 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
Come on Gary, you know 100+lbs hanging over the front wheels has a much greater effect then 100lbs added to the center of the car. Thats not even Basic physics.
Old Jan 4, 2013 | 11:31 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: 454 swap
I agree, the extra 100 lbs is going to change how the car handles. IMO this is not going to be a cheap easy, worthwhile swap for a street car. Sure it can be done and would be cool if done right, but IMO just build up a nice SBC and you will have less cost and be happier in the long run.
Old Jan 4, 2013 | 11:33 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
Yep. I had a wicked 427 in mine for awhile. Thought about detuning it for street, but decided to sell it and build a mild small block.
Old Jan 4, 2013 | 12:08 PM
92 BBC Z's Avatar
Re: 454 swap
Your opinion is based on what, your experiance building a BBC 3rd gen?
Old Jan 4, 2013 | 07:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 454 swap
The weight on my front tires is about the same as a factory third gen with a SBC in it. I'm considering putting more weight on the nose just to keep the front end down.
Comparing apples to apples. Yank out the SBC and put it on a scale. Chances are you're not going to install a complete original BBC. Even just an intake manifold swap is a big weight saving. Getting rid of the cast iron exhaust manifolds because you can't use them anyway and installing headers is another weight saving. Although iron heads work fine, aftermarket aluminum heads are well within just about everyone's budget. They don't need to be high end heads. Once those have all been replaced, the engine is pretty close to the weight of an OEM SBC.
Don't forget, the increased torque of a BBC will easily overcome the slight weight increase.
Old Jan 5, 2013 | 08:51 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
Ok, so the op has not replied, so this is probably a dead topic.
But from what I was gathering he was looking to swap a stock low power bbc for some fun on the street.
IMO, this is a waste of time.
Now, if we was looking to go racing, then, yes, a bbc is a great platform.
For a mild street car, IMO a smallblock is a better choice.
I have had and still have both, BBC and SBC powered cars.
Old Jan 5, 2013 | 08:53 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
True, if he was building something, as stated, he wanted to pull the engine from the farm truck and drop it in, no rebuild. Sounds like his budget would not be enough to buy any heads.
Old Jan 5, 2013 | 04:43 PM
92 BBC Z's Avatar
Re: 454 swap
Your sbc argument/position is sound. all im sayin is, if some one had told you, before you built yours, "dont build that" would you have listened?
Old Jan 7, 2013 | 06:10 AM
Car: 1971 Camaro
Engine: 427
Re: 454 swap
The only reason I went BBC was because I decided to go outlaw street car racing. If I had known it would go back to a real street car, I would have never gone with a BBC.
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
