Who here has this swap?
Old Dec 12, 2012 | 05:28 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
I have a 87 IROC. Came with a 305 TPI The car now has a 5.7L out of a 91 Corvette. If you have this swap please let me know
Old Dec 12, 2012 | 05:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
re: Who here has this swap?
The Corvette L98 was pretty similar to ours. It came with aluminum heads. Maybe different camshaft?
https://www.thirdgen.org/forums/engi...-f-body-v.html
I'm also guessing it's speed density since f-bodies got those '90 and on.
I guess what exactly is your question?
Old Dec 12, 2012 | 06:34 PM
Car: 1987 IROC-Z
Engine: 6.2L
I, and when I mean "I" i mean me and a mechanic shop cant get long tubes on the car. I tried Heddman....then the shop tried....then i bought Hookers. Im beyond pissed and frustrated
Old Dec 12, 2012 | 07:07 PM
Twin_Turbo's Avatar
Should bolt in just like that, dimensionally exactly the same apart from agle plugs vs straight and I have angle plugs on 2 of my irocs and the headers fit just fine.
To get long tubes in you may have to jack up the engine a bit depends on how worn your engine mounts are and maybe the tolerances on those headers. I'm guessing they are hitting the K member? Might need to notch it a little
Old Dec 12, 2012 | 07:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hedmans need the a-arm perch trimmed on the driver's side if i recall correctly, and number 3 primary needs a dimple where it passes the k-member. i can't speak for the hookers as i've never use them. i had a set of 113s on a 305 and a 350 and dimensionally identical to your swap.
Old Dec 12, 2012 | 07:25 PM
Car: 1987 IROC-Z
Engine: 6.2L
I bought new motor mounts. Didn't fix the problem. This shop has huge lifts like most shops.
Old Dec 12, 2012 | 07:31 PM
mw66nova's Avatar
Engine: 7.0L
where is it hitting? hedmans have to go in from the bottom also. if you have the stock humongous starter, it will need to be taken out to get the header in the whole, and then the header and starter will need to be mounted at the same time.
Old Dec 12, 2012 | 07:33 PM
mw66nova's Avatar
Engine: 7.0L
did you read this sticky on hooker 2210's install by chance?
https://www.thirdgen.org/forums/exha...oker-long.html
Old Dec 12, 2012 | 07:34 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Perhaps this will help with the Hookers.
Old Dec 12, 2012 | 07:35 PM
Engine: 385
Lol, got me Matt.
Old Dec 12, 2012 | 08:14 PM
Car: 1987 IROC-Z
Engine: 6.2L
I just read that and took notes. Will call the shop and tell them about what I read. I will say this. I hear all the time on this board how "easy" it was for so-and-so to install their headers. I think yall are all full of ****. I installed some on my LS1 car before and there were some issues but this is just ridiculous. A brand new part, made for a car shouldn't have all these kinds of issues. people claiming how "easy" it was just reminds me how people on the internet will say whatever to make them look good
thanks for the link
Old Dec 12, 2012 | 08:30 PM
mw66nova's Avatar
Engine: 7.0L
um....it was "easy" for me...
you never answered my question: where are they giving you a hard time?
"bolt-on's" never are man...
Old Dec 12, 2012 | 08:39 PM
Engine: 385
+1
Old Dec 12, 2012 | 09:08 PM
Car: 1987 IROC-Z
Engine: 6.2L
Im not sure because i haven't worked on the car in over 3 weeks. I work 75 miles from my home and only go there on weekends. They're closed on weekends. Im guessing the primaries. not sure
Old Dec 12, 2012 | 09:22 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
thanks for the link
Maybe the people at this "shop" you're having install them, well, just suck ?
Old Dec 13, 2012 | 01:46 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the Hedman long tubes slid right into my car from the bottom without lifting the engine off the mounts, but i did have to ding one tube on each side to clear something on the frame and but that only took a few minutes.. they were probably the easiest install i've ever done of brand new headers fresh out of the box. my car is a factory non AC car, and i did them without the oil filter or starter installed. but there was a ton of room for the HD starter i originally put in there, and the LT4 mini starter looks absolutely tiny in that huge gap. the big K&N oil filter i'm running isn't even close to the headers.
Old Dec 13, 2012 | 07:17 AM
Engine: 383 SBC
I've had my hooker long tubes on and off a few times. Driverside from the top. Passenger side from the bottom rotated in and bolt starter in after. Passenger side collector merge hit barely on the K member A arm mounting flange. Which appeared to be a common issue as the eBay set of headers were already dented there. I used an angle grinder and knocked a tad off to get clearance. Now that I've switched to a tubular doesn't appear to be an issue at all.
Normally issues with bolt-ons it comes back to the car being tweaked slightly from normal use over the years or other parts are causing issues. Big thing with the headers is to remove spark plugs, starter, any other sensor wiring that might be in the way, and try to install them like stated in the threads.
Frankly I can't stand most shops. Prices around here are crazy. $500 for 3800 series intake gasket job when I can do it in under 3 hours with $80 of parts. 2-3 hours for a transmission cooler install. $300 labor for a heater core install. Even when I have most of them work on stuff I end up having to take it back apart anyway and fix or correct something they've messed up so I've basically given up on shops for most issues.
Why are you going long tubes?
Normally from what I've read the differences between shorties and long tubes are around 5 HP difference until either large cubic inches, power output increases, or high RPM. Then at that point you have to decide is it worth the headache. I've rebuilt the Mufflex Y pipe already once and still not happy with the fitment. It's just a pain to get long tubes with Y pipes around a 700-R4 with Spohn Crossmember mounted torque arm. Don't get me wrong long tubes look and perform great once in it's just like putting 10 lbs of crap in a 5 lb bag.
Old Dec 21, 2012 | 12:16 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Who here has this swap?
thanks for the link
Thats funny.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
