starting a swap
Old Dec 15, 2012 | 08:25 PM
littlevin91's Avatar
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
starting a swap
starting my first swap im going from tbi to a carb and wirings not my strong point i need to know what wires need to be connected to to get the engine started,how to hook up the ignition and etc.
Old Dec 15, 2012 | 10:20 PM
91zl98's Avatar
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
Re: starting a swap
You will only need the switched ignition power to the coil and tachometer if applicable tci makes a lockup kit for the 700r4.
Old Dec 15, 2012 | 10:32 PM
Engine: 5.0 v8
Re: starting a swap
and all the other wires from the battery to the starter and to the alternator are the same?
Old Dec 15, 2012 | 10:36 PM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
Re: starting a swap
Not sure how much your ripping out. But you need the purple wire from the ignition switch to the starter s solenoid . The bat to starter charging system wires and tbi uses the fan relay and coolant temp sensor on the passenger head to control the cooling fan.
Old Dec 15, 2012 | 10:43 PM
Engine: 5.0 v8
Re: starting a swap
the fans already hooked up to a switch but what about the alt what goes to that
Old Dec 15, 2012 | 10:53 PM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
Re: starting a swap
I don't have a schematic for your car but I think there are 2 wires on your alt brown that goes to the charging light and red that goes to the fan relay both stay .
Old Dec 15, 2012 | 11:15 PM
Engine: 5.0 v8
Re: starting a swap
so i only need to run like 4 or 5 wires?
Old Dec 16, 2012 | 12:18 AM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
Re: starting a swap
I think I covered all the engine control wires.
Old Apr 8, 2013 | 12:26 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Re: starting a swap
On my starter, i have 3 red wires to power and a single purple wire(not sure what its called) from the key, since my VATS is out, i have push button on my 91 RS carbed.
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
cstrobel65
Aug 15, 2015 10:19 AM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
