Engine bore
Old Jan 8, 2013 | 06:19 PM
Richgta's Avatar
Engine bore
How much gain do u get out of .20 over
Old Jan 8, 2013 | 06:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine bore
Eleventeen
Old Jan 8, 2013 | 06:24 PM
Re: Engine bore
I don't know of ANY engines that can go that far. That's almost ¼". Very few engines can make it to .060" reliably, let alone .200".
Can we assume you mean .020"?
If so, that depends on how bad the condition was before... if it was like-new, you might MAYBE gain in proportion to the increase in CID; which for a 350, whould be around 3 CID. A little less than 1%. So, probably 2 - 3 HP. IOW, so close to zero as to be imperceptible... less than the effect of adding 1 psi to your tires.
Old Jan 8, 2013 | 06:27 PM
Richgta's Avatar
Re: Engine bore
Whay about adding a cam
Old Jan 8, 2013 | 06:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Engine bore
It's kind of like asking "how long is a piece of rope?"... there's not enough parameters in the question to provide any kind of answer.
Old Jan 8, 2013 | 08:54 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Engine bore
I think I see where this is going...
When you bore a motor, don't think of it as a performance gain. Yes, their is some gain from it but it's minimal. I can build a comparable 350 and 350 bored .030" and you wouldn't know which is which. Taking a poop before you get in the car would make just as much of a difference.
Anyway, we would need to know the size motor you are starting with as stated.
Old Jan 8, 2013 | 09:01 PM
DancesWithDeath's Avatar
Car: 1991 rs camaro
Re: Engine bore
Lol...
Old Jan 8, 2013 | 09:14 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Re: Engine bore
"Taking a poop before you get in the car would make just as much of a difference."
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
