2.8 V6 to SBC 350 question
Old Feb 5, 2013 | 01:10 AM
86RedFirebird's Avatar
Car: 86 Firebird
Engine: 2.8 fuel injection
I'm getting ready to start this swap in the summer but with tax time around the corner I was thinking of getting parts now. My question is which parts from the V6 can I use on the 350? Thanks guys, and I will post pictures as I go, I will also be painting this summer lol
Old Feb 5, 2013 | 01:11 AM
project89's Avatar
Re: 2.8 V6 to SBC 350 question
are u doing a carb swap or fuel injection swap?
nothing from the v6 can be reused including the transmission
u have to change the front springs to v8 springs and also change the engine mounts
Old Feb 5, 2013 | 01:21 AM
Car: 86 Firebird
The v6 is fuel injected and the 350 is carb...
Old Feb 5, 2013 | 01:23 AM
project89's Avatar
u will have to change the fuel pump in the tank.modify the sending unit to use a mechanical or low presure pump
or u can leave the stock pump and run a return style regulattor to ring fuel presure down to 4.5-7 psi
Old Feb 5, 2013 | 01:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
the 350 is carb...
https://www.thirdgen.org/carbswap
http://5finger.8m.com/tpi2carb/tpi2carb.html
and a lockup control for the convertor if running a T700 trans
https://www.thirdgen.org/forums/carb...c-control.html
Old Feb 5, 2013 | 01:40 AM
Car: 86 Firebird
I have a 700R4 trans
Old Feb 5, 2013 | 07:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you talking about the TH700 behind your V6, or something else?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
Zane Story
Oct 8, 2015 12:40 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
IROCZTWENTYGR8
Nov 26, 2000 02:02 AM
