Motor mount Removal
Old Feb 13, 2013 | 05:58 PM
Cars'n'Guitars's Avatar
Car: 1985 Camaro Iroc-Z
Engine: Currently Deciding
Transmission: TH350 Built
Axle/Gears: 3.73 POSI
Motor mount Removal
What is the best way to remove the motor mounts on a v8 car? Also what is the exact size socket needed to remove the bolts?
Old Feb 13, 2013 | 06:25 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
Re: Motor mount Removal
easiest way...grinder and a centre punch no fussing around with extensions and universal sockets coming up through the frame thats how i did it..bolts are cheap better to replace then reuse just my 2 cents
Old Feb 13, 2013 | 06:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
15mm
Old Feb 13, 2013 | 07:28 PM
Any tips or tricks to get the bolts out besides cutting them out?
Old Feb 13, 2013 | 07:40 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
extension with a universal swivel socket on it through the cross member for the bottom bolt and socket on the top ,loosen then remove bolt
Old Feb 13, 2013 | 07:46 PM
Okay that's what I was thinking but I wasn't to sure if I'd have enough clearance for the socket on top.
Old Feb 13, 2013 | 08:10 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
take the front suspension out, once the a-arms are out it's easy
Old Feb 13, 2013 | 11:37 PM
five7kid's Avatar
True, but putting the A-arms back in is more hassle than doing the nuts with the A-arms in there.
Old Feb 17, 2013 | 03:25 PM
Okay I haven't really been working on pulling the motor yet but now that I have another motor to be put back in its crunch time. I was looking around on it today, I was looking at the topside with the bolt heads. There is a nut on the backside of these bolts correct? And if so would be easier to raise the front end to access them?
Old Feb 17, 2013 | 03:46 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yes there is a nut on the backside
Old Feb 17, 2013 | 06:56 PM
Okay thanks, I figured so that just made this 100 times harder.
Old Feb 18, 2013 | 04:20 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
why is it your removing the mounts? are you upgrading or is one cracked? no one has asked this yet and just seeing that your doing it to remove the motor you only have to remove one bolt from each side
Old Feb 18, 2013 | 05:59 PM
It is being done to remove the motor, as far as I can see there is nowhere on the mounts to remove the motor with one bolt. Can you show me some pictures of what I'm missing?
Old Feb 18, 2013 | 06:24 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
here is a picture... that big gold bolt will be the one your removing not the 3 on the k member...the is a nut on the back of it the sizes you will need are a 5/8 and a 13/16 if i remember correctly
Old Feb 18, 2013 | 06:31 PM
Okay I was thinking that but the bolt on mine is out already so I thought they were different than other motor mounts I have seen. Okay thanks for the picture.
Old Feb 18, 2013 | 06:48 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
the bolt is out on both sides? if so pull the motor lol
Old Feb 18, 2013 | 06:51 PM
Yeah I believe so, I was anticipating more work, not sure if the torque converter bolts are out though. But other than that I believe its ready then.
Old Feb 19, 2013 | 04:20 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
are you pulling the tranny all out at once? might be easier unbolt the trans mount and the torque arm as well as the trans lines slowly pull it out and dont let the drive shaft drop
Old Feb 19, 2013 | 06:53 PM
No tranny is staying in the car.
Old Feb 28, 2013 | 05:06 PM
chevyv8guy's Avatar
Car: 84 firebird
Engine: 355
ok so all you have left to unbolt is the tranny,TQ converter bolts,fuel lines,power steering pump,manifold bolts,and remove the distributer cap so it doesnt get damaged and you have a little more clearance..i think thats all i might be forgetting something but im sure youll figure it out if you havent pulled it already!
Old Feb 28, 2013 | 05:12 PM
All of that has been done already, was wondering about mounts because I overlooked it like an idiot. I have been waiting to pull the motor because the weather has been pretty crappy this last week.
Old Feb 28, 2013 | 09:01 PM
Blue1990camaro's Avatar
im in the sabe boat here, at the same point in my project as you are, wheather is killing me
Old Feb 28, 2013 | 09:04 PM
Haha yeah I hate because it just sits there and I know I have everything to do it but can't. Also while im on here is it easier to put headers on before or after the swap?
Old Feb 28, 2013 | 09:11 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Just don't panic when the motor doesn't come off the mounts right away. The first time I ever jacked a motor up, I was because the motor wouldn't raise up off the mounts. Turns out it was still sitting on the suspension. Oops. I actually made a post on here thinking my motor mounts were rust-welded to the motor lol.
If you do happen to replace the motor mounts for poly or new rubber oem, be ready for a chore. GM idiots didn't weld the nuts to the inside of the K-member like they should have, so that instead of just removing the bolts, you have to hold both. The nuts also have washers on the inside of the K-member. Easiest way to put these back on is by using RTV or similar gasket maker, and making it stick to the nut being held by the socket. Be ready to utilize an extension, a universal, a 15mm socket, and a long long list of curse words. Feel free to make up your own curse words too. That's what I did when I switched my mounts out for poly
Not exactly a walk in the park.
Old Feb 28, 2013 | 09:13 PM
Engine: 385
Depends on the headers. I don't think any will go in with the motor at the same time. Some just slip in from above or underneath. Others you need to jack the motor up a bit.
Old Mar 1, 2013 | 04:36 PM
Not at this moment but whenever the 355 goes back in it will, as for the nut depending on how I see it I will probably just weld it back on to the cross member. And thanks for the header tip.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
NBrehm
Aug 5, 2015 07:57 PM
