is it a 327/350 or 302
Old Feb 18, 2013 | 06:32 PM
mightymike's Avatar
i have a block i picked up from a friend it had been sitin in his shop since before he got there, i figured it was a 350 and he didnt need it so i got it cheap
here's the deal i been lookin up the vin and casting numbers and cant figure it out i called a dealership and the guy i spoke to told me its defiantly a 68 but it could be a 302 a 327 or a 350 i haven't pulled the pan off yet though so i dont know if its a 2 or 4 bolt yet but if anyone can help me out or give me more info with just the numbers that would be cool
here's the #'s VIN: V02I7YH Cast: 3914678
if you can save me the time of goin to the machine shop id appreciate it
Old Feb 18, 2013 | 06:40 PM
Re: is it a 327/350 or 302
If it's a BLOCK, it's not any of those things.
But according to the code, it WAS:
http://www.nastyz28.com/gm-chevy-cod...-suffix-10.php
Scroll down to YH
Pretty much a small-journal, not worth much boat anchor.
Old Feb 18, 2013 | 07:52 PM
mightymike's Avatar
Is there a way I can ban you from my posts man cus the only thing iv learned from you is that you don't know a god damn thing its not bear block its a long block got all the internals and since when is a 327 a boat anchor, do people a favor and shut up
Old Feb 18, 2013 | 08:34 PM
i have a block
All I know about what you've got, is what you wrote. Being a jerk about it doesn't change that. But of course, your post WAS somewhat vague, so I carefully qualified myself by saying
If it's a BLOCK,
327s have been boat anchors since the 350 came out. That's when I quit building em; only took getting my butt whupped twice before I figured it out. (Except of course in "matching #s" situations, which obviously we are not in one of) I was young; first time I still thought I was smarter than anybody else, second time I discerned a pattern.
I will GLADLY ban myself from any further posts from you, if you so choose. Your loss. I really only prefer to talk to people who want to LEARN THE TRUTH, anyway.
Old Feb 18, 2013 | 09:00 PM
mightymike's Avatar
I'm vague? I told you what I had and the info for it. All you told me is to go to the first site you found on google and said my engine is a pos didn't help only when I insulted you did you put words together in sentence's that sounded like knowledge
Old Feb 18, 2013 | 09:36 PM
I'm vague?
Well; maybe not. You said:
i have a block
My bad for misunderstanding what A BLOCK is. Maybe there was mention somewhere up there of all those other things you didn't seem to say you had? I can't really say.
That site has been around longer than Google has, even if you have not.
Your "engine", if that is indeed what is it and NOT what you SAID it was which was A BLOCK, is apparently a very common ordinary 1967 truck motor; and a 327 at that. Nothing special, valuable, worth much, and especially not particularly worth spending money on if the object is to COMPETE WITH anything not rules-restricted, as I found out while build my last couple of 327s back in the mid 70s (and getting my butt whupped by the relatively newly available 350s).
I realize you're kinda new here, this being your 5th post and all; so I'm cutting you some slack. Just telling the truth, not making anything up or whatever. I'm not sure what you expected to find out by posting that here, but you'll find that just having people worship whatever old thing you've got just because ... you've got it .... (??? I guess that's why you seem offended that I'm not woshipping? Iunno, just a guess) isn't really what this site is all about.
Plainly you don't recognize knowledge when you see it, so that's fine too. It's not my car that will be the one going slow because of it.
Have a lovely day. It's been a pleasure making your acquaintance. Good luck with that.
Old Feb 18, 2013 | 11:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a disconnect somewhere. According to https://www.thirdgen.org/forums/engi...g-numbers.html , that casting number would be:
3914678....302.....68....2...Z-28 Camaro
3914678....327.....68....2
3914678....350.....68....2
Wouldn't be the first time that list was incorrect, but I wouldn't tend to believe it for this number. That would be a large journal engine. Casting numbers can be mistaken (looks like a 3 or 6 when it's an 8, 1 when it's a 7, for instance), but there isn't anything close with those choices. All Google hits on the casting # said it was a '68 (except for an eBay listing, which used the date code to say it was a '67 - still a '68 model year block). I'd guess the VIN was misread (the stampings can be faint). Or, the listing is in error for that suffix.
But, doesn't really matter. Pull the pan, either get the crank casting # (which is what will tell you what it really is), Google that; or pull a bearing cap and measure the journal size.
Old Feb 19, 2013 | 06:16 AM
If it were to in fact turn out to be of some "value", such as a "numbers matching" setup for something, find somebody who wants a "numbers matching" setup for that, and sell it to em. Don't tear it down. Leave it alone and as unmolested as possible.
If it turns out to be a 67 truck motor like the stamping code would indicate, get rid of it; it's not really any good for anything.
If it's a 4" block but has any less stroke than that, and is large journal, but isn't a "numbers matching" setup for anything "desirable", then it's basically just a 350 block same as any other older 350 block. Build a 350 out of it.
Don't worship it.
Old Feb 21, 2013 | 10:15 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you get a free 327, and just want to end up with something better to drive than a 305, and more responsive to mods than a 305, there's nothing wrong with a 327. It probably needs a re-ring job, at which point it's better to score a good used '87-up 350. Sell the 327 to a restorer and the 350 is a free upgrade. Heads: If the heads are 64 cc and 1.72" / 1.50" valves, then sell them to a restorer, and at least get some 416s. At this point you're still not out any money. Even if the 327 and the 350 both get built to 300 peak HP, the 350 will have more average HP. The 327 might do 1 MPG better on the interstate, but no guarantees.
Reborn756
Sep 4, 2015 03:42 AM
Bird_of_Prey
Jul 7, 2012 05:19 PM
Azarel
Dec 9, 2001 08:56 PM
blue86iroc
Aug 27, 2001 03:31 PM
Intense92
May 12, 2001 09:34 PM
