Torque Converter Won't Go Onto Transmission
Old Feb 27, 2013 | 04:13 PM
McChoka's Avatar
Car: '82 Z28
Transmission: TH-350
Axle/Gears: Posi
I removed the torque converter to make sure everything mounted right. I can get the TQ most of the way on, but there's a last 2-3 inches I can't get it to go. Ideas on what this may be?
Old Feb 27, 2013 | 04:25 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: Torque Converter Won't Go Onto Transmission
Are you rotating it as you are holding up and pushing it in?
five7kid's Avatar
Transmission: 4L80E/4L80E
Usually that's the front pump tangs not aligning with the slots in the converter.
Old Feb 27, 2013 | 04:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Maybe you should 1st mention ?????????
https://www.thirdgen.org/forums/tech...anny-onto.html
that you stuffed up taking it apart and were warned you may have damaged something when trying to put it back together
so guys are fully aware they are not dealing with a typical convertor install problem
The fact you broke part of the bellhousing trying to jam it back together makes it highly likely you damaged
the convertor or input parts of the trans in the process; given that would be the only thing that stopped everything sliding together correctly
Old Feb 27, 2013 | 05:33 PM
Chad85T/A's Avatar
Car: 85 T/A
Disregard what I said earlier. That would've been helpful info.
Old Feb 27, 2013 | 06:15 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
lift up slightly in the center **** on the torque convertor and rotate it. It'll slide right back in place. don't use any artificial way of force on in.
Old Feb 27, 2013 | 07:56 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Read his original post , he has already tried that method and broke things
Old Feb 28, 2013 | 06:20 AM
Car: 86 Camaro Z28
that's what happens when I don't read things completely. I didn't realize that was his post.
Good news: if it is a TH-350 you can get a new bell housing for it. all you do is cut off the old one and it bolts to the front of the oil pump.
Bad news: you may need to purchase a new torque convertor and oil pump. I recommend taking it to a transmission shop to have them inspect it and inform you of what needs to be replaced. then have them replace the parts as needed. I'm pretty sure they could do the bell housing at there too.
Old Feb 28, 2013 | 07:35 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Remember the convertor clutch inside the convertor. That bastard needs to hop onto the gears as well and that's where I once quit with a new convertor. Couldn't get it on.
So while pushing it on, keep rotating and slightly tilting it. At some point you'll feel it move on a bit more.
Old Feb 28, 2013 | 08:38 AM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
This is probably my issue.
The only thing I broke was the bell housing. Luckily I'm friends with a mechanic and I had him come inspect it. Everything checked out. I'm just having trouble putting it on.
Old Feb 28, 2013 | 08:58 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Make sure theres no pilot bearink in the crank from the new eng . bet thats how the bellhousing broke!
Old Feb 28, 2013 | 09:36 AM
Car: 86 Camaro Z28
http://www.jegs.com/i/J-W-Performanc...oductId=748597
Old Feb 28, 2013 | 10:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How could that be?
Old Feb 28, 2013 | 06:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So how come the mech didn't fit the convertor to the trans as that would be the only sure way of " checking " it ?
And the reason for that is ....?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
