350 TPI Swap
Old Apr 8, 2013 | 06:34 AM
JoshGuynes's Avatar
Car: 1986 Camaro Iroc-Z
Engine: 383 coming soon
Transmission: Pro-Built/Jasper 4L60
350 TPI Swap
So my '86 has the 305 that all the Iroc's came with and I'm beginning to get quite bored with it. So, I'm swapping in a 350 TPI. I was wondering if anyone could give me info on what parts (links if you've got them) to make a good 350-400hp out of the 350. Like, can I get that kind of power from Vortec heads, a cam, mini-ram intake, etc. I do plan on forging the internals or something along those lines. I don't want to hear anything about just doing a 383 (even though I'd love one) but it's just not in the realm of possibility for me right now. I just want a nice cruiser with some get up to it. Already have a beefed up trans going in this week and I am doing a rear end swap.
Old Apr 8, 2013 | 03:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 350 TPI Swap
the cost between building 350 and a 383 isnt really all that much if youre replacing the entire rotating assembly with forged stuff anyway. its really just the cost of the machine work on the block. which depending on where you go can be just a couple hundred bucks.
if all you want is a nice cruiser with some get up and go, get a vortech 350 from a 90s truck, slap it in with a carb and go cruising. they are all over the place and can be had for cheap in good condition. if you want to keep fuel injection and have some cash to spend, the LS swap is the popular choice. they are becoming more and more plentiful and have a ton of aftermarket support to put one in nearly anything.
Old Apr 8, 2013 | 06:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 TPI Swap
Originally Posted by JoshGuynes
quite bored with it. I just want a nice cruiser with some get up to it. .
Most important factor you don't mention is your budget
As noted , once you start replacing the internal parts, the only cost difference of a 383 is maybe a hours worth of labor
to clearance the bottom of the bores for the larger crank ( which you can do yourself for free anyway )
Cost of all the rotating parts is identical ;350 vs 383 for a substantial power increase
Old Apr 8, 2013 | 09:10 PM
JoshGuynes's Avatar
Re: 350 TPI Swap
Damnit...lol my budget is around $2500ish. I plan on just being a used 350 TPI and going from there. I want something that's basically plug and play except for changing ECU's etc.
Old Apr 9, 2013 | 04:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 350 TPI Swap
No need ,
for a stockish 350 TPI all you need is a 350 TPI memcal ( tune) in your existing TPI ECM , some 22lb 350 injectors
and a 350 knock sensor to replace your 305 one
Even with a radical 383 you can still use your existing ECM with a custom aftermarket tune
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
