Just starting on planning for swap into 91 Z28 Conv not sure which way to go yet
Old Jun 29, 2013 | 03:05 PM
Big Davve's Avatar
Car: 1991 Z28
I recently bought a 91 Z28 convertible, which has always been a car that I've loved a lot, since they were new-the same year I graduated from high school! The car is in great shape body and interior wise and runs fine, but like a lots of us guys here, I want to swap something else in for the motor. I'm totally open to anyone's suggestions here and although I know my way around cars pretty well, I'm pretty much a newbie as far as engine swaps go. I'd be most likely looking to have a shop do the swap for me, I don't mind wrenching on cars if I have to, but I'm a pretty busy guy and just don't have all the time required.
Here's what I'm looking at for what I want to end up with, budget, etc.
Budget: I'd like to keep it under $10,000 TOTAL, including the shop labor, the more under $10k I can go, the better!
Performance: Obviously, I want something faster than the stock 350 it as now, its a totally stock 350 now, I think they were 230hp or so in 91? I'm not looking for a 10 second car or anything like that, just some more power than stock, maybe 300 to 400 hp when done. I also like a motor with some torque, too!
Reliability: I want it to be reliable, again I'm not looking for crazy power
So, I'm wondering which engines do you guys think I should start looking around for and where to look? My brother's got a 2001 or 02 Tahoe with I think the 5.3 V8, which I'm still surprised how well it moves that big Tahoe around. I think that one came stock with 300hp and lots of torque, would something like that be an idea for a swap or ????? I'm totally open to any suggestions here.
Also, since my Z28 comes with the standard 4 speed auto (I think thats the 700R4 right?) should I be looking at swapping the tranny and rear end, too? Thanks!
Old Jun 29, 2013 | 11:49 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Just starting on planning for swap into 91 Z28 Conv not sure which way to go yet
IMHO, if you're paying for labor and have a budget, an LSx swap can get to be spendy as there's a zillion little details that need to be attended to. A mildly built 383 with an after market/modified LTR TPI set up will give you good power, great torque and not break the bank as it basically falls in place of the 305. Your 700R4 should hold up pretty well as will your stock rear end as long as your right foot isn't crushing the carpet constantly. The ratio, though, is less than conducive to fun. It's a 2.73 which will yield a fabulous top end and improved fuel economy at the expense of acceleration. Check out this article: http://xtremecarzone.com.au/index.php?showtopic=386
Old Jun 30, 2013 | 01:05 AM
Big Davve's Avatar
Car: 1991 Z28
Thanks for the advice and the article, its an interesting read. This also led me to my new discovery, I feel like a bit of an idiot now (at least a little bit) but I thought my car had a 350 in it, now I realize its a 305! I guess I'd assumed it was a 350 all along and I can't say I was misled by the seller at all, because I never really brought it up!
OK, so with that out of the way, what you're saying is to look for a L98 350 to swap in there and have it built up somewhat like in the article. 410hp and 500 lb ft of torque would be more than enough for me!
Old Jun 30, 2013 | 03:29 AM
watajob's Avatar
Car: 92 T/A 'vert
Those are numbers from a 383. Check out my sig for a mild 350. It's about 350 horse and 450 torque, flywheel. It's not the quickest car at the track but it's a hoot out on the street, with a TPI's instant throttle response and low end grunt.
Old Jul 1, 2013 | 01:52 PM
drunck1's Avatar
Car: 1991 Camaro RS TBI Convertible
Engine: V8 305 5.0
I took the easy way out... I just finished the setup of my 91 RS / LT1 4L60e swap. I have come out of pocked about 1K just on gasket kits, heads lapping, and Trany rebuild. the LT1 is a straight fit... small modifications must be done such as power steering lines need to be made and fuel lines. K member is the same, Trany one is the same. I started with a complete donor a 95 Trans Am which I bought for 400. I just need to finish up the wiring...
Old Jul 1, 2013 | 02:43 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
the 5.3 take out engines are pretty cheap and have power and efficiency. you just need the computer. you could use the 4l60 from a 2wd truck and just have the pcm tuned to run them both. no reason you shouldnt get mid 20's for fuel economy with that, maybe better the trucks get 20-22
Old Jul 2, 2013 | 03:49 PM
watajob's Avatar
Car: 92 T/A 'vert
K-member and trans cross-member need major surgery or to be replaced, which ain't cheap either way if you're paying someone else to do the work.
Old Jul 3, 2013 | 03:59 PM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
I spent the better part of a year going back and forth on LS vs small block. Buying a 5.3 or 6.0 truck motor or even buying a wrecked van/truck still put me easily near 5k for the job. I finally decided on an L31 because all of my accessories and tranny bolt up. I bought an HSR (but there's lot of choice there including the TPI) and with reworked vortec heads or even aluminum and a mild cam, I think that's it'll be a lot fun for half the LS swap. I've got buddies with Z06's and CTSV's. I'm never gonna catch them anyway(the CTSV just keeps turning up the boost) so I decided to enjoy what I have and a few bucks left over.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
L98GTA87
Aug 5, 2015 11:02 PM
