82 Camaro v6 2.8L to v8 350 sbc Swap
Old Aug 26, 2013 | 01:17 PM
Wrencher87's Avatar
I started out in the V6 section because I thought we were going to just fix the v6. But it has turned into a v6 to v8 Swap. Here's the original thread. https://www.thirdgen.org/forums/v6/6...maro-2-8l.html
We are switching a 2.6L V6/TH200 to a 5.7L V8/TH350.
Is there anyway to get around having to buy a Torque Arm for the TH350 Tranny in a stock 82 Camaro?
Would it be ok to use washers under the Engine Mounts so we wouldn't have to move the brake lines?
Also need some advice on what style Headers to get that would leave clearance for a Stock starter.
Thanks in Advance.
Old Aug 28, 2013 | 09:42 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 82 Camaro v6 2.8L to v8 350 sbc Swap
There's no way around buying the relocation bracket for the torque arm. And you need to move the engine mounts forward on the k member anyways so after you move them you can reposition the brake lines with little force.
Old Aug 28, 2013 | 02:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Using washers under the engine mounts would bring them closer together, and keep them from aligning with the engine.
As said, you can easily reposition the brake line. It doesn't take much to rebend and reroute it.
If you use a 153-tooth flexplate/flywheel, any 3rd gen specific headers will clear the starter.
88rscamar0
Sep 23, 2015 09:08 PM
Night rider327
Mar 29, 2003 11:15 PM
loomdog32
Nov 26, 2001 09:02 PM
JoelOl75
Apr 2, 2001 06:55 AM
