Alternator Wire Harness?
Old Aug 29, 2013 | 05:38 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I'm swapping in a 350 carbed into my V6 car. Do I need to keep the wiring from the harness that goes to the alternator or can I just run the 1 battery cable to the alternator? I will be running a serp belt set up so I'm not sure which alternator I can use, an old 1 wire or am I ok with the a V8 alternator from a 3rd gen?
Old Aug 29, 2013 | 08:06 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Alternator Wire Harness?
There are various v8 thirdgen alternators. Some 2 wire some 3 wire. Not sure if any singles.
If you are using thirdgen serp setup, keep the wiring harness. The 2 wire runs one wire to the starter/battery connection point, and the second goes to the fan fuse. The 3 wire has both those and another wire to the L terminal, some setups use that for activating the alternator via ecm. I forget exactly where that wire goes, have to look up the diagrams. My 89 was 2 wire. The 86 firebird harness i have has 3 wire
Old Aug 29, 2013 | 12:07 PM
drdave88's Avatar
Engine: 6.0L
I wont be running an ECM, so is that connector needed at that point? Would i need something else to control the voltage regulator (i assume that is what the connector is for)? I am cutting out everything that I dont need from the harness.
Old Aug 29, 2013 | 12:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No the alternator harness is separate from ecm, unless its a 3 wire then one may go back to ecm. I am not sure but the 2 wire definately does not interact with ecm.
One big red wire goes to starter where battery power hooks to, and other goes to fan fuse block thru the driver side firewall connector.
I would use a alternator for the thirdgen serp belt setup and use atleast the big red wire part on the connector. If you use factory electronic fans then also keep the fan fuse wire or relocate a fuse and run back to power at battery to shorten the wiring
Old Aug 29, 2013 | 01:14 PM
drdave88's Avatar
Engine: 6.0L
The big red one is separate from the harness I'm talking about. There is that one, then a (I believe) 3 pin connector that goes to the alternator. The harness ran to the V6 alternator that was on the pass side. I'm getting brackets from a 4.3L that has the alternator on the driver side.
If I understand right, you're saying the 3 pin connector controls the fan fuse? It has nothing to do with the voltage regulator? Also, I only have a single fan that will be controlled by a toggle switch. I will try to get ahold of a wiring diagram for it, that may clear up some of my questions.
Old Aug 29, 2013 | 01:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Need to find a diagram for the v6 car. I thought they may be similar to v8, but i guess not.
Old Aug 29, 2013 | 07:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The Alt operates independently of the ECM .It needs the above noted input through a resistor or the idiot light on the L terminal to
excite the Alt so it begins charging
http://alternatorparts.com/cs130_sbpage3.htm
There is usually a input to the ECM but that is only so the ECM can monitor the system voltage and make adjustments accordingly
There is no feedback ECM to ALT or control of the ALT
On the CS-130 there is also a (3rd ) voltage sensing wire that the Alt used by the internal regulator to determine how much voltage is present
in your charging system.
In retro fits this is typically just looped to the main BATT terminal on the Alt
Old Aug 29, 2013 | 09:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
My 89 diagram only uses terminal S and F. L is not present. On my ls1 411 ecm, there is a ecm wire that goes to L but i am not wiring it in. I dont think its needed since i never ran it before
Old Aug 30, 2013 | 10:21 AM
drdave88's Avatar
Engine: 6.0L
I got it now, ok cool. I bet that also controls the gauge on the dash. Thanks guys!
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
