tbi vs. mild cam
Old Sep 5, 2013 | 04:54 PM
rebelson101's Avatar
Car: v8 s10 and a stock 1989 firebird
Engine: s10 is 355 firebird is 305
Transmission: 700r4 full man valve body in s10
Axle/Gears: 3.55 in s10 2.73 in firebird
tbi vs. mild cam
i did some looking and i have found people that say yea no problem and some that say no it wont run lol
so the question remains.....
i have a 1989 firebird tbi 305 and i just built a 355 with comps biggest 4x4 cam in it new springs new retainers so on and so on 882 heads (yes i know) flat tops stage 2 rods good for 500 hp new crank so on so on any way the cam is a 489/501 lift and 274 duration i was kinda liking my tbi because this engine is in my s10 now and tbi is just so nice on cold mornings i was thinkin ac heat four seats and a good sound with fuel injection and come lope best of all worlds but im wonderin how the tbi will take that cam? let me say first off ive ran carbs my whole life and lets assume I KNOW NOTHIN OF THIS MAGIC INJECTION any help will be great and
Old Sep 5, 2013 | 07:51 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: tbi vs. mild cam
Way too much cam for TBI.
Old Sep 6, 2013 | 12:26 PM
what would be the side effects? would it not run or would it not idle or could it be livable? i will eventually put a carb on it im sure but i was wonderin if it would be livable to drive for maybe a year or so untill i finish the rearend and th350 turbo w/stall ect..
Old Sep 6, 2013 | 03:45 PM
cosmick's Avatar
If it will idle, it will be pig-rich, and then at higher RPM those LO3 injectors won't supply enough fuel, and that TB won't flow enough air. A custom chip could get a 2-steps-smaller cam to idle decently, but you still won't get enough fuel, even if you swap the TBI from a 454.
Old Sep 6, 2013 | 04:39 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
What numbers are we looking at? TBI can be set up for some decent hp, from my experience it is mandatory to have EBL flash to tune and run a custom TBI engine.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ambainb
Aug 29, 2015 12:43 AM
nuggie
Aug 25, 2015 01:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
