Uh oh..tpi manifold bolt holes don't match older heads?
Car: 88 IROC Z28
Engine: 385 Stroker
So everything was going great with my engine build, right up until the point where I tried putting in the center bolts into the stock '88 tpi manifold.
That's when I found out that the bolt angle is different than what my new (albeit older cast iron '77) heads want (hey..it looked ok loose fitted on the stand at the time :-( ).
I really don't want to grind away the holes on the intake or ditch the investment in my heads (2.02/1.6) if I don't have to, so does anyone know if there is some adapter I can use, or a maybe a different manifold option out there etc.?
Thanks in advance
Thanks in advance
Re: Uh oh..tpi manifold bolt holes don't match older heads?
If you don't want to slot your intake bolt holes, but have '77 heads with 2.02" intakes in em, then I'd suggest throwing that performance-killing smogger stuff in the trash, and getting GOOD heads that also fit your intake.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
As long as all the ports and passages line up, slotting the mounting holes shouldn't hurt. Good luck with your build.
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
I've slotted mine myself and no leaks on two different intakes on two different engine builds
Car: 82 Z28
Transmission: T400
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Are there any issues with the bolt head clearing the runners when you slot the intake like that?
Car: 82 Z28
Transmission: T400
As discussed here ;
all you are doing is making one style intake fit the other style head.
Engine: 383ci SBC
just seemed pretty tight under there as I was taking it off of my 88. Figured I would measure twice by asking the dumb question before I cut once.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
