15-320 canton oil pan
Car: 1986 I roc
Engine: 494 bbc
Transmission: turbo 350
need help fast . does anybody know if this oil pan will work on my 1986 camaro I have a 494 BBC thanks
Re: 15-320 canton oil pan
Should at least clear the crossmember, steering, and exhaust.
"1986" isn't a factor at all. 82-92 will all be the same.
The starter and the right lower control arm mount, I couldn't say. That, plus worming your exhaust between that and the chassis, is where the variables will be.
This hobby isn't, as I'm sure you know by now, always a matter of "buy this and bolt it in". There's generally some risk and/or adaptation and/or surprise parts incompatibility (in your case, headers and motor mounts) involved.
