2.8 v6 with manual trans to 350
Old Jan 6, 2014 | 08:31 PM
Canucksfan1's Avatar
Car: 1987 z28 I-roc
Engine: Carbed 350
Transmission: 700r-4
Axle/Gears: Stock
Hey all, been browsing the site for a few weeks after purchasing an 89 rs. I really wanna do a 350 swap, older carbureted engine, and want to keep it a standard trans. So my question is what are my options that aren't going to cost me an arm and a leg? Was thinking maybe an older 4 speed as the newer 6 is a little more then the wife will let me spend, but I'm not sure where to start. Any help and info would be greatly appreciated.
Old Jan 7, 2014 | 12:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 2.8 v6 with manual trans to 350
https://www.thirdgen.org/forums/tech...formation.html
1st need to work out how you are going to mount the torque arm with a non 3rd gen trans
you might be able to use a aftermarket TH350 or TH400 cross member depending on 4 spd trans mount location
http://www.umiperformance.com/catalo...bdq3liis264de1
http://umiperformance.com/catalog/in...roducts_id=300
Then there is this
http://www.spohn.net/shop/1982-1992-...nsmission.html
Old Jan 7, 2014 | 07:27 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If you want to keep a manual trans (I assume you have one now) you can use the T5 you have in there already...... depending on what you're looking to do with the car. It's not the best option, but on a budget, it will absolutely work. All you will need is a V8 bellhousing, flywheel and pressure plate. Then get a 14 spline clutch disc. http://www.speedwaymotors.com/Flathe...ion,38143.html
Old Jan 7, 2014 | 07:25 PM
Car: 1987 z28 I-roc
Engine: Carbed 350
Axle/Gears: Stock
Updated my profile.
So i really don't know how I would adapt a non 3rd gen trans to bolt up a torque arm, will start looking into that. I was just hoping there would be some other option that would require less money the a t56 swap.
If not then I guess I will have to go auto or stick with the t5 until it decides to let go.
Old Jan 8, 2014 | 06:03 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
So GOOGLE is your friend
A basic search shows T10 / Muncie / Saginaw all are 23" from bellhousing to trans mount
A T700 is 22 1/2" so a aftermarket T700 crossmember with torque arm mount would come close if you slotted the trans mount holes
Spohn actually offer a T10/ Muncie crossmember , click on the trans type option box
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
Old Jan 10, 2014 | 07:15 PM
Car: 1987 z28 I-roc
Engine: Carbed 350
Axle/Gears: Stock
Well after a fair bit of research and pricing out parts I guess I am just going to save up and do the t56 swap. Thanks for all the helpful links and info.
Zane Story
Oct 8, 2015 12:40 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
L98IROCZ89
Jun 22, 2001 04:59 PM
AC
Mar 19, 2001 03:51 PM
racer_75
Jul 24, 2000 01:19 PM
