95 350 block change for a 87 305
Old Jan 23, 2014 | 10:45 PM
Mike Kinsey's Avatar
OK, so I have an 87 iroc 305 and I want to go to a 350. Question, what from my 305 would I still be able to use on the 350 block? The 350 block is from a 95 camaro.
Any info would be greatly appreciated.
Old Jan 23, 2014 | 10:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 95 350 block change for a 87 305
https://www.thirdgen.org/forums/tech...formation.html
Originally Posted by Mike Kinsey
The 350 block is from a 95 camaro. .
Were you actually planning a LT1 swap ?
A completely different scenario to just pulling out a 305 and replacing it with a reg GEN I 350 from a car or truck
A '95 Camaro engine is not a GEN I SBC like your 305.
It is a GEN II LTI , completely different , you need the LT1 heads ,intake , water pump ,dist , computer and lots of other parts to make it work
The block on it's own is next to worthless, your 305 starter and oil pan will fit
If you had a engine from a '95 truck however, then you could use all your 305 parts , intake , heads , dist, water pump ,exh, etc
Old Jan 23, 2014 | 11:26 PM
OK that's what I thought. I new the water pump and distributor (Opti) would be different. I just didn't know if everything else would be.
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
