Please, HELP me (Giulio from Italy)
Old Mar 31, 2014 | 10:16 AM
Giucas77's Avatar
Hi, I'm Giulio from Italy. I have a big problem:
My car is an '82 Pontiac Trans Am.
Engine is 305 5.0 V8 Crossfire injection.
I've changed Intake manifold (Edelbrock #2101) and I've add a carburator (Edelbrock #1406).
My friend tell me that I need a new distributor with vacuum advance. I don't now what type is correct for my engine. I don't know if I need mecanical or electronic. Please, can you help me? Thanks a lot
Old distributor (Crossfire) is on the left
Old Mar 31, 2014 | 10:20 AM
Twin_Turbo's Avatar
Re: Please, HELP me (Giulio from Italy)
Yes, you need a vac advance fully mech distributor, not an EST distributor like on FI systems
Old Mar 31, 2014 | 10:42 AM
Giucas77's Avatar
Please look picture, distributor on the right is correct? How can I wire it? Thanks
Old Mar 31, 2014 | 04:10 PM
Twin_Turbo's Avatar
Get a HEI with coil in cap, chuck that old thing on the right.
wiring:
http://www.route66hotrodhigh.com/HEI.html
Old Mar 31, 2014 | 06:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
[/COLOR][/LEFT]
The one on the right will work, but it's a points-type distributor. You need a "ballast resistor" as well to drop the voltage down to 6 volts. You would wire it to the "BATT" wire from your original distributor.
But, I don't think you want to go that way. Twin_Turbo has the better route. You really want an electronic trigger type distributor, not points.
Old Mar 31, 2014 | 07:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need one that looks like the one on the left but a non computer controlled version with a vacuum advance on it.
Old Apr 1, 2014 | 03:09 AM
Giucas77's Avatar
I need it, but please, can you post an ebay link to buy it?
I find this announcements, what distributor is better for me?
http://www.ebay.com/itm/171267252929...S:1123&vxp=mtr
http://www.ebay.com/itm/380670072498...S:1123&vxp=mtr
http://www.ebay.it/itm/GM-CHEVY-V8-H...item3f2f979cbb
http://www.ebay.it/itm/HEI-Distribut...item23378d5a4a
http://www.ebay.it/itm/HEI-65K-Volt-...item258b40cd64
http://www.ebay.it/itm/Chevy-50K-Vol...item3ef41da0ad
Old Apr 1, 2014 | 03:16 AM
Twin_Turbo's Avatar
http://www.ebay.it/itm/Chevy-50K-Vol...d=612643380336
that one
Old Apr 1, 2014 | 03:34 AM
Giucas77's Avatar
This is better? (65k vs 50k)?
http://www.ebay.it/itm/HEI-65K-Volt-...d=612659905258
Old Apr 1, 2014 | 04:12 AM
Giucas77's Avatar
I also finded this: http://www.pertronix.com/prod/ig/flame/dist/hei.aspx
Old Apr 1, 2014 | 04:21 AM
Giucas77's Avatar
And this:
http://www.ebay.it/itm/Pertronix-D10...item58a2abb648
Do you think it is the best choice?
Old Apr 1, 2014 | 11:56 AM
five7kid's Avatar
Any one of them should work, but the Pertronix is probably better quality than the others.
Old Apr 1, 2014 | 01:24 PM
Giucas77's Avatar
And this?
http://www.ebay.it/itm/New-MSD-8365-...item3cdddf7ad9
Old Apr 1, 2014 | 01:41 PM
five7kid's Avatar
Better than the Pertronix. But, whether or not it is worth the extra money, that is up to you.
Old Apr 1, 2014 | 01:50 PM
Giucas77's Avatar
But now i have a problem, they asked me if I have a SBC or a Pontiac engine . . . My engine was Lu5 crossfire injection, 305 5.0 V8. I've changed intake manifold (#2101 Edelbrock) and add a carburator (#1406 Edelbrock).
I have to buy a distributor for Pontiac or Chevy? :-(
Old Apr 1, 2014 | 01:52 PM
Giucas77's Avatar
#2101:
http://www.edelbrock.com/automotive/...ormer-sb.shtml
Old Apr 1, 2014 | 01:54 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You need a SBC chevy motor. All of our motors are chevy regardless of being a firebird or camaro.
So again you have a 305 SBC Chevy v8
Good luck
Old Apr 1, 2014 | 02:11 PM
Giucas77's Avatar
Thank you very much to all
Excuse my ignorance, I'm used of Fiat engines :-D
Old Apr 1, 2014 | 02:17 PM
midias's Avatar
No problem, ask all the questions you can and if the translation is not clear feel free to say to
Old Apr 1, 2014 | 02:18 PM
midias's Avatar
65 vs 50K will not matter in your application
Old Apr 2, 2014 | 04:48 AM
Giucas77's Avatar
Excuse me, I have another question:
Originals Spark Plugs are good? I have RV19YC
Old Apr 2, 2014 | 07:27 AM
midias's Avatar
Those are OEM and should work just fine.
Tarizza
Sep 24, 2015 12:57 PM
NiG
Nov 25, 2014 06:26 PM
mosquiton_001
European Region
Dec 3, 2008 07:16 AM
