Engine Swappin 305 to 350 Hecho en Mexico
Old Apr 20, 2014 | 03:26 PM
Scrap Metal Guy's Avatar
Car: 1987 Pontiac Firebird Base
Engine: 1986 10066030 Target Master 5.7
Transmission: 700R GM Auto
Axle/Gears: Factory
Ok. First thank you 3rd Gen for the Birthday Wishes.
Now, down to bidness.
I save numerous parts from the factory 305 that I took out of my 87' Bird. It had and aftermarket 1406 Edelbrock carb, and a "Red" aftermarket Distributor. The "Newer", but "Older" 350, has an Edebrock Air Gap intake. When I tried to install the distributor onto the intake, it's about an inch too tall from the adjustment bolt. Should I look into a whole new Distributor, or am I missing something here because of the after market intake manifold on the 350.
Ps, since my absence, I scored a set of Chevy Headers and True Duals off an Old 77 Nova at LKQ here in Gainesville Florida. The whole package cost $62.00
Old Apr 20, 2014 | 10:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine Swappin 305 to 350 Hecho en Mexico
Did you rotate the dist shaft to line up with the oil pump drive in the block so it will drop into position ?
Old Apr 21, 2014 | 05:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hopefully you can find someone to buy it, because none of it will fit a 3rd gen f-body.
Old Apr 22, 2014 | 11:17 AM
Axle/Gears: Factory
Yes I did. I even turn the harmonic balance so the oil pump shaft would show the Number 1 Cylinder position on the Distributor for reassembly purposes. The Distributor itself just will NOT "seat" onto the Intake properly. There are no Obstructions on the Distributor. (Like in the Slot where the oil pump shaft goes) and there are no obstructions in the Block because I looked with a flashlight. The Older 305 distributor just seems to have a longer shaft???
Or I was thinkin maybe it had to do with the Air Gap intake?
Old Apr 22, 2014 | 03:04 PM
five7kid's Avatar
The distributor shaft length hasn't changed since 1955. Doesn't matter if the intake is stock, "high rise", "air gap", or whatever.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
