350 swap / NO Computer?
Old May 8, 2014 | 11:35 PM
'Jones82TransAM's Avatar
Car: 1982 Pontiac Recaro Trans Am
Engine: 350 Chevrolet V8
Transmission: TH400
Hi, Can someone please offer me some advice on this subject. I was originally intending to put a 383 stroker into my 1982 Pontiac Trans Am, but have decided to build a 350 chevy instead. Bearing in mind I am not required to have any emissions control in my country, It has always been my intention to make the build as mechanical as possible. I am also intending to put in a TH350 trans, and replace the computer controlled Quadra Jet out. Is it at all possible to completely remove the computer and make everything completely mechanical? If so, what would the undertaking be? And is it worth it?
Old May 9, 2014 | 01:59 AM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Re: 350 swap / NO Computer?
Uh.. Run carbed?. Cars ran without computers for decades.
Old May 9, 2014 | 03:23 AM
Transmission: TH400
Thank you for your reply but I guess what I am asking in addition is what other things I may have to do, for instance maybe changing out the distributor with a vacuum advance for a non CC carb? I hear the TH350 trans does not require lock up switch modifications but again I am not sure. I am also hoping that someone may be able to confirm what other vital functions are dependant on the computer so I don't miss anything.
Old May 9, 2014 | 10:58 AM
jesse.allen's Avatar
Car: 1983 Camaro Z28
Engine: Carbed - 350
Axle/Gears: 3.23 - Posi
Hello 'Jones82TransAM,
I did the same thing in my car. I switched the carburetor to and non-cc Edelbrock and the distributor to a non-cc version. After that the computer really served no purpose. All of the wires that were coming through the firewall on the passenger’s side were now useless and I removed them. I also removed all of the computer stuff from under the passenger dash. I currently have very little wiring in my engine compartment and none of it is computer controlled. I also ripped out all of the emissions stuff and that saved a lot of space.
As far as your transmission, the TH350 is not computer controlled or anything but it does have an electronic lock-up.
Jesse
Old May 9, 2014 | 06:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Only the late model version
Old May 9, 2014 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by 'Jones82TransAM
Can someone please offer me some advice on this subject. ?
Do a search on here ;1001 threads on carb swap requirements
Start here
https://www.thirdgen.org/forums/carb...um-please.html
Old May 9, 2014 | 10:47 PM
Transmission: TH400
Thanks vetteoz and jesse, much appreciated for your experience and putting me in the right direction I will check out this thread.
Old May 9, 2014 | 10:57 PM
Transmission: TH400
That's a good thread, thanks again for pointing me in the right direction
bellez77
Sep 5, 2015 08:39 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
