efi 406 build, hp expecting? possibly turbo?
Old Oct 12, 2014 | 08:18 AM
trevor1010's Avatar
Alright i have a 88 irocz 305tpi iam in the process of building a 400sbc 30 over.. so far i have bought the weiand stealth ram kit, afr 195 heads 65cc, xfi 280 retro fir hydraulic roller cam 280 288 duration @50: 230 236 valve lift 576..eagle rotating assembly all forged mahle pistons, h beam rods 6 inch and a forged crank... what type of horse power could i expect and could i possibly throw a turbo on this set up
Old Oct 15, 2014 | 03:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
65cc heads will build a lot of compression with the typical flat-top/4-valve-relief pistons. Any idea what the pistons actually are?
Personally, I would never build a high performance 400 with a factory cast block. At a minimum, you should put a half-fill of Hard Blok in it.
While you might be able to turbo it, again, I wouldn't with a factory block. And, if the compression is as high as it sounds like it may be, you're going to need some very good gas.
NA, with a good tune and good exhaust, it should be north of 450 HP at the crank. 500 HP, even, maybe.
Old Oct 15, 2014 | 03:35 PM
trevor1010's Avatar
Re: efi 406 build, hp expecting? possibly turbo?
Flat top two valve relief
Old Oct 15, 2014 | 03:37 PM
trevor1010's Avatar
Yes its a stock block, with 2 valve mahle pistons flat top...eagle said my compression should be 53.79:1, I go by last two digits right lol 9:1
Old Oct 17, 2014 | 05:20 PM
five7kid's Avatar
Not being sure what your deck height or head gasket thickness is, CR would be more like 11.9-12.0:1.
65cc heads on a 406 with flat tops makes for a pretty tight squeeze.
Old Oct 17, 2014 | 06:56 PM
trevor1010's Avatar
Is that bad
Old Oct 18, 2014 | 07:42 AM
trevor1010's Avatar
Should I send them back an get 75cc
Old Oct 24, 2014 | 10:13 PM
Hoff701's Avatar
Car: 1992 Rally Sport
That's up to you, and what you want to do with the car. Worst case with zero deck, CR could be up to 13:1 with 65cc's, depending on your head gasket too. 75's would get you down a little over a full number probably.
But hey, is this a track car only, or are you gonna run it on the street with pump gas? (Good luck with anything higher than 12:1) Meth injection might be something to look into as well
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
trevor1010
Aug 24, 2015 11:29 AM
89-S-dime
Aug 12, 2015 11:57 AM
