Pulling engine and tranny together?
Car: '86 Trans Am (White)
Engine: Its a tree fiddy
Transmission: 1/2 of a 700r-4
I was wondering if I could pull the motor and tranny out of these cars as one unit. Its a 350/700r4 combo, and it looks like theres a chance itll fit. Thanks for the help.
Car: 88GTA
Engine: 5.7TPI
Re: Pulling engine and tranny together?
Yup, done it on a 89 GTA 5.7/Auto.
With hood off.
Just watch you boom length and capacity's!!!
With hood off.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
it can be done - taking the distributor, crank pulley, and radiator out first make it much easier
Ok, thanks again. I know our equipment can pull the weight too, it lifted a 7.3 powerstroke.
Car: 88GTA
Engine: 5.7TPI
Car: 1988 Camaro
Yep done it many times.
Only thing I remove is the distributor, carb, headers
Car: 1989 Trans Am GTA
Transmission: M28 T56
Yep, can be done.
Car: 1988 Camaro
1st pictures engine/trans going in. No rad. in car yet
Second pic engine coming out of a camaro to go into the firebird, rad and all was being swapped too.
Third pic is engine going into firebird
1st one is a 355/th-400
The other two are 327/th-350 long shaft
Car: 1983 Z28
Engine: 385 Fastburn
Yup, like what's already been said, pull the distributor and carb, and put a cap in the end of your transmission so you don't bleed it all over the car as you pull it out, haha.
Car: 88GTA
Engine: 5.7TPI
RED EVERYWHERE!!!!!
So yeah, might want to duct tape it on REAL GOOD!
Car: 1988 Camaro
Yep, you can see the plastic bag on the end of tranny on all 3 of the pics I posted. Old slip yoke in end of trans, bag over that, and duct tape around bag and tailshaft.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
It was doing well.
