Please opine on this combo I'm considering buying
Old Dec 28, 2014 | 12:26 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
454 machine work 2 bolt ARP studded block, bored .030, hot tanked, crankshaft bore checked out fine. cylinders have been finished honed to pistons.
Eagle ESP 4340 crankshaft Std/Std with Clevite H rod and main bearings
Summit Racing sfi damper and sfi flexplate
Eagle ESP 4340 Hbeams with Arp2000 bolts
Mahle Powerpak pistons with moly rings. 8.0:1 Cr
Electronically balanced within +/- .5gram
Comp Cams NX298HR, 298/310 2400-6500 242/252 @ .050
Crane Hyd roller lifters. these are used but were sent to crane and check out fine. matching comp springs
049 fully ported oval port bare heads
Mellings HV oil pump.
Moroso chrome pan with pickup.
MSD pro billet HEI distr. Used condition but very nice
MSD 6al
MSD BTM Module
BorgWarner Airwerks S475, with T6 1.32 A/R Twin Scroll Turbine Housing.
Rated at 500 to 1050+HP
High-flow S400 model, with compressor flow over 105 lb/min.
Wheel Dimensions:
Compressor: 74.7 mm inducer, 100.8mm exducer, with Extended Tip Technology.
Turbine: 95.5 inducer, 87.9mm exducer.
Housings: Compressor: .63, with 5.0" hose-type inlet, and v-band-type discharge.
Turbine: T6 1.32 A/R, with twin volute, T6 turbine inlet flange, and quick-release v-band discharge flange. Cast in ductile iron.
*Custom made upsweeping turbo manifold. was made for a tall deck and will need to be modified to work with a std deck block.
Old Dec 28, 2014 | 12:27 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
Re: Please opine on this combo I'm considering buying
Does this seem like a well matched combo? Cam number is 11-414-8
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
roysatikas
Sep 22, 2015 08:15 PM
F-body-fan
Sep 17, 2015 12:16 PM
z28guy134
Sep 1, 2015 11:50 PM
